Mynock cave - Falcon Oxygen Mask
What do you think?
I found this thing on ebay, in Austria.
But I think I will make a mold of the cartridge holder when I have it finished.
Hope you don’t mind me using your pic. I’ll take it down if it’s a prob.i don’t think it’s a match. Look at the distance from the top to the hole. It also appears much larger than the one used. It’s darn close though. We are close!
No problem using the pic. I know, it‘s not exactly the used part. They may have been several versions of the CO2 cartridge holder. In between I identified 6 different types of holders And this one is the closest I found.
If someone of us is lucky to find the exact matching one it will be no problem to throw this one away and replace it ;-).
I took again some time to study the pics. If you have a close look you can see that all three of the canisters Leia, Han, Chewie) have the milled notches (see added pics). And after comparing all available angles in the pics I have, I‘m now pretty sure, they also used the the same cartridge holders. These sparklers were very common at this time, so it would have been no problem buying three of them for building the props.
I‘ve finished the hose connector/CO2 cartridge holder part. I bend an aluminium sheet to cover the open parts of the cartridge holder mounted it to the siphon head and filled the whole thing with putty.
I drilled a hole into it to place the hose connector.
Ok gang. I found the correct side piece. I do not have it but I located a picture. Take a look. It is made by BOC and came with one of the models. I am told this bulb holder is rare. Of course.
What did you use for the side nose greeblies?
I recently found a better alternative to what I used and I have it on the way. The air vents of these goggles are almost perfect. I will add a metal tack to the center
