Limited Run 2nd Run - ROTJ Endor Rebel Helmet 'Halo' Vacuum Formed Shells
Just wanted to give an update where it's at. I'm making sure the material im planning to use works under the temperature and pressure involved in the vacuum forming process using another mould made with the same material before I move forward to build the moulds to start this run.
Thanks again
New moulds are currently being printed. Once they are done I'll be handing them over to be formed asap for a run of 9 sets.
Attached below is also a photo of the haircell textured plastic to give you an idea of the inside finish of the part, It does slightly differ from the texture seen on the inside of the auctioned production helmet but after months of checking different suppliers this was the closest of the bunch.
Thanks for your patience and sorry for taking so long to get this rolling.
