Limited Run 2nd Run - ROTJ Endor Rebel Helmet 'Halo' Vacuum Formed Shells
Surprised to see no one else wanting the textured/haircell option. Here is the production made shell PropStore auctioned off. You can see the texture in the inside.
Yeah, from what I've seen, a lot of the rotj helmets used textured ABS.
In case people got the wrong idea from my first post, the texture will be inwards facing and not seen on the outside of the helmet like that propstore helmet.
While it may be more accurate, it's a detail that's hidden inside the helmet and won't be seen so it's not a priority for me.
In terms of glueing the halves together I'm thinking the gloss will have a better hold once they're sanded down and have the sanded ABS tab attached. In my experience, having adhered similar haircell textured plastics together, they didn't have as strong a bond as two smooth plastics that have been sanded and stuck together due to the slight uneven texture.
Add in the fact that I'm getting two kits, I'm trying to keep my costs down.
Thats it for option 1s with the plastic I have on hand. I'll be ordering some of the haircell for another project within the next weeks so i'll send a photo of its texture when i do.
No worries, man. I'm keen on seeing it when you get the haircell in.
Sorry for the confusion, i put you down for the last 3 i'll have gloss plastic to produce. Moving forward the offering will be exclusively textured ABS.
There is one gloss option available. If it turns out there are more people interested in gloss over haircell as well I'll buy more gloss plastic for the run.
Update:
I've found a new supplier for the white haircell ABS, and can get it for a similar price to the gloss ABS from the last run so have reduced the price of that option accordingly. I have ordered a sheet and will send some photos of the texture once I receive it to make comparison against the propstore photo.
The texture will be very similar to that of the production helmets, however as the haircell texture changes from manufacturer to manufacturer it won't be exactly the same.
