Do you happen to know if the Only & Sons one has a specific name? Looking for one the now on various second hand sites.
No, there was just the label of the brand, I removed it before tweaking the color.
I found it at a second-hand market.
But Outerknown East Bank sweater you tracked (not availabld here for me), it looks way better, sturdier, even if probably more expensive (I paid mine 5€! My size,same condition as new, ready to be dyed)
guys, you can’t imagine how many times I received compliments from girls like “wow, what a cool sweater” :cool:
and not only from girls :)
that's exactly the one I was looking for, I guess no more possible to be found.
I actually like my honeycomb versions I settled on, but this is the real first choice of the two sweaters I was thinking to keep for my k style outfit, to be part of my wardrobe, but I fear it will remain with the two I have
unfortunately yes, it was sold back in 2015 - 2016
precisely, it is what confirmed by Uniforms of the Screen
I can do some works by me, but I wouldn't even know how to start to make such a pattern on the shoulders, and anyway, it would need to have a high-end garment as the Theory one seems to be, as a base to start
here today we have a cloudy blade runnery sky, I took a one dy break from my activities.
Days ago I did a long process in my free time in the evening, cause during the past tweaking and fails, on my bep there was a ugly lite, barely visible (but visible) stain of ironing (on a cloth which in theory, should never be ironed, I did low tempwith baking paper to protect it when trying to fix on it one of the acrylic medium I tried months ago).
So I washed it again twice in a dedicated way, then treated it with salt and vinegar, and also ammonia, retouched the color again to even the treated parts with the rest, I can confirm one more time it's barely impossible to remove the wax completely once you apply it, however I rewaxed again then restrentghened the coating close to perfection after this last operation.
Ironing stains completely removed, color perfect, did the same precise job I did on the SR at the bottom to make it more SA and postured, with also piping etc.
Now, the bep is still a bit shorter than SA (as from the beginning, of course), I reopened the collar since the zippered hidden chest shield I featured on the inside, can make up perfectly for airflows to the throat protection (and the collar is still a buit too narrow as originally, but a little better and SA now).
I re-increased the quilting on the sleeves again, and it's simply amazing to me now (in these quick raw pics collage, I'm also wearing it raw and ready with just a t-shirt underneath).
The biggest SA inconsistency on the SR, is just the abundant folding of the lapels, but they stays before the shoulder line when open and looks great anyway, to do better, I would have meant to completely resize them, losing also the strongly double-breasted setting my SR has on me and which I actually like so much with a incredibly tailored snug-fit, as if they had made a custom size for me, so that's the very end anyway and I confirm my satisfaction, it will be really hard to choose which one to use during next cold season, I can say that if you do heavy waxing (as I did on my bep to finally recover it, instead of the lite one I did on SR where a heavier one, after struggled so long to have that cloth, would've been a nonsense to me), you will have a coat more suitable for hard cold (together with a proper lining) and also harder to be scratched in any activity I could undergone wearing it.
Hi guys, how are you doing? Hope well,
Here it will take more than a bit before wearing the coats, but I figured that waiting for cold season and having to deal with waxing again if needed, wasn't a good idea.
In the end, I decided (for me, just my humble pov, possibly well matching Mechanismo 's vision) that SR, despite being great and coated anyway, was needing for a heavy Otter wax coating.
After having tried on both coats the 3 main waxes designed for fabric dressing (Otter both dressing and bars, Barbour dressing, and Greenland bars, I would have tried also Kuhl but it wasn't that easy to be bought here where I am), I can give a personal view of these waxes and what about any possible good improvement on Bep laminate and SR, my very last:
- in the end, I must say that, if the color was more SA and the lining more quality and sturdiness, I personally and honestly don't see that big difference between Bep laminate and SR, but that laminate, as originally received, needs a bit of light sanding to loose the excess of plastic-like effect, which is not too much, but a step back than SR. The laminate, for the brave ones, may have a strong need to be tweaked in color (so, discolouration -very carefully- in a large tub bleach bath without folding it, then I would suggest powder dyes in a single washer cycle at 60° (very tough to be withstood, but if just one and not thousand like a I did, you might avoid having to deal with minor scratches / lining to be replaced etc), I would say using a total of about 1000-1200g of powder in a mix of grey in the larger part, emerald green, a bit of blue denim (light/sky blue) and a very little part of brown, just to give an example of what I did, and than, why not, adding a final lite coating with Otter wax.
- Otter wax is very long to cure, not hard to be applied but needs several hands -I'd say 3/4 without exceeding in none of them and waiting each time for curing at least 72hrs- to have to desired result, I put the first hand with fabric dressing, then retouched it, and others with bars. One of my intermediate hands has been done with Greenland bars, I don't find it useful to be used as the only coating, but that wax helps to give a bit more stiffness (adding it in small proportion starting with extremely light hand and waiting, to understand how much you desire) and weight/sturdiness to the cloth,but also speeds up a bit the wax drying time;for Greenland, a careful use of the dryer is mandatory, it won't be enough to use the hands as I did on some retouches after the first hands, to push it through the fabric and make it absorb it properly, it needs the dryer; I didn't find the same great result with Barbour wax, maybe it is more effective on duck canvas, I finished a tin anyway to improve the coating especially on the back of both my Bep and SR, but it is clear to me that, at least on these two types of cloth, Otter (and in case, a bit of Greenland) has a greater effect and I wouldn't have needed Barbour wax too.
Do not care to what instructional says: for me, it takes at least about a month to completely and properly cure, and what indicated about 48/72hrs is for the prominent part, but it still remains slightly damp for a long time, imo it's better to wait and avoid it absorbing too much dust by going around wearing it immediately.
- maybe it sounds bad to someone, but I personally find my final result, after have tried all waxes and in the end fully agreed with Mechanismo as well as many noticeable ones who said the movie coat is waxed, superior to the original coating I had from SR: with this, I mean SR is a particular unique beautiful coating but I wanted more of a "filled",saturated weave and make it also stronger to elements, so that I gave a couple more waxing hands (make it quite strongly waxed too) on my SR after the first lite I did at the beginning, and the effect is a more SA and sturdy feeling (I'm sure that will also assure me my SR have a way greater resistance to time, I don't wanna risk it to be never easily scratched or any damage by using it).
Leaving aside for a moment SA, I find that the my coats now have great practicality for about every activity and situation (except using it as a pure training apparel, I definitely won't be delusional wearing my k coats when skiing or running sessions), but if rain or heavy fog/cold wintery situations occur, my solution with the nylon hood, now I thought it wasn't stilysh enough at today, so I created a couple cotton skullies, colored in the same hue of the coats, and coated at perfection with the waxing methods I found work best, they are very easy to be folded and carried in a internal pockets of the coats, and when the coat is fully closed, they definitely work to withstand also a rain a bit more than just lite (even if not comparable to a gtx sporty hardshell).
Waxing those cottons, waiting couple days and then exposing to a bit of sunlight, helps cure properly even if the sun tends to bring out a lot of excess dry wax (which will be visible with whitish streaks, which will require further work to make them reabsorb or to remove them), but by repeating with light hands several times, in the end you will have a good result.
Probably it might also be enough to use radiators in winter to dry the wax properly, but I chose summer and these methods also because I want to have my clothes already nice, ready and finished, when this time cold season will come.
See u next!
Hey all,
I'm thinking develop a new Blade runner coat that designed earlier days.
What do you think guys?
I already saw around some alternatives with four pockets, this one could be more practical using the lower ones, personally I'm well satisfied with mine after I added hidden zipper every external pocket too.
It seems longer here, it should be an improvement of the SA, many of the best replicas tends to be a little shorter.
Imho I think, if you improve your collar pattern a bit (wider in proportion), as well as the lining, your coat is already great right now. The one I had from you, at today is way shorter because of my modification, and the laminated dark cloth, as well shown here, needed to be worked a lot (clearing and changing the color, and also a lite sanding to reduce the plastic like aspect it has when new), but in the end I'm so satisfied with the final result, in many aspect I find it superior to my SR (that is another great coat after I modified it).
Always too bad you didn't find a way to have laminated cloth like your twill, but in duck canvas weave...after all, I think I could tweak color and coating again, it could be so close to the movie, even if I won't complaint mine as it is now and I'm fine with what I have about this coat.
I hadn't resisted, tried some new distressing methods for the fur, using ipa diluted I already knew it works successfully together with some semi permanent spray hair dyer, mixing some brown and grey tones...in the end, the proper distressed fur was a classic for this coat, so I put it back, also inspired by Adam Savage vid, both on my bep and sr
Hi Guys,
now that I can go through my very first winter wearing my k coats from the beginning, I'm figuring out any other little details that can be possible and actually deserve improvement
...I have to say that I'm finally quite comfortable and I don't see much else that could be tweaked.
I only made a couple of (I think final) adjustments:
- on the bep I was lucky, because the laminated PU fabric that I had chosen, in addition to having an excellent effect after all the mess I made with it, still has good elastic properties that by using it for a while, in the end made acceptable and less serious the fact that the collar is too tight to close, since in fact it stretched a little by itself and it feels less tight; however I made one last rather radical change, tightening the end of the sleeves a bit starting from under the elbow and increasing towards the wrist, this made it much cooler because it has a less loose and a bit tighter effect in that area, approaching the film effect, it could be a piece of advice both in view of a possible revision of the model, and for those who have it and want to make (or have made) the necessary changes
- although I had already made the pattern of my SR very satisfactory since I had bought it by optimizing it in the collar-lapels section and making it more SA, walking around I still found the open lapels too wide, and although they did not end beyond the shoulder line, it was just a question to better set the limit in which they fold out, so I implemented additional internal elements that made the shape limited to the right size in an even more defined way
I have to say that in general, the SR despite being long as SA (my Bep came out a bit shorter in the end) and in general giving the feeling of a great garment, often gives me too much of a non-casual, luxurious taste and it's set more like a dress, although with the current modifications I wear it as it happens to me without problems, but in general, both for the greater softness (at least of the laminated twill fabric, then I don't know who has the duck canvas) and for the distressed style that came out of it and that I really like to wear for routine, I often end up wearing the bep
Here u can see the increased tightness for the BEP cuffs, and the fixed shape and size for the SR lapels
FYI and anyone who might want to take inspiration...
...and today, same place I hiked yesterday, but this time wearing SR. The lite today was brighter, however it can be useful for the ones who want to see how the coats shine at daylight, even if it's not that useful comparison to the movie (where for all the duration, there's no clear sunlight).
As said, I won't get into cosplay (but if the chance will come easy in my area, I might always put a band aid on my nose and join it for a time) but pragmatism must always be there with such an effort, an expense, and dedication to the project, so the final test I planned to do at the end, was exactly this: go hiking twice, one time wearing each coat, possibly not with the harshest weather but in mountain environment and almost winter temperatures, as it is now here. Both the coats passed the tests, and even if not at same level of technical clothes, after all that tweaking, they are also confortable and good performing in any occasion, confimed. Both days, I ride a motorbike for more than half an hour to reach this mountain hideout, and with the inner shield I implemented, by also closing it, they hold well those rides also.
See you in the future, when any chance will come to take a shoot of the coats in an even more blade runnery, wintery, metropolitan atmosphere
oops, I forgot, I posted the BEP hiking session of yesterday on another group and not here since yesterdat, rpf server seemed not working properly, so here I put it now; I add also some other pics from that day when in the city, the effect is not the same in all pics since it was more of a foggy day (on the kickscooter, I'm wearing the SR)
Hi guys,
today I saw back the women teddy sherpa jacket I used for the fur, in a OVS shop.
Since winter is just beginning, of course they are selling it full price, not cheap at all, and I cannot even see it on their website yet, but it's probably on the way to be updated.
The fur is very thick, for me it was perfect to also pad a bit more the lapels, but if you aim to a less "swollen" of them, maybe better another one, however I find it very quality and SA, with a XL size I managed to cut enough for my SR and my BEP and I still have some left for two of the three pieces needed for any other replacement, I'll probably get another one just to have it as spare parts but not before end of cold season when they will do the highest discount.
FYI
Nope, that was me! :)
