Interest ROTS Obi Wan Belt Hanger
Our Civilized Hero iterations are as follows:
FX KIT- $375
- clockable booster and pommel.
- primarily carbon steel construction
- copper and brass neck sleeves
- spring loaded plungers under clamp
- accurate clamp card material
- asymmetric grenade valleys and grenade vertical milling
- our carbon steel covertec
This would include:
1x Allen key for blade retention screw.
shipped in official Civilized Hero packaging.
STATIC KIT- $250
This will be a non installable version representative of the materials and construction of the original prop including…
- vacuum metalized chrome plastic emitter, box, and body
- stainless steel emitter base and greeblie
- copper neck and greeblie
- brass windvane
- plastic grenade and booster
(delrin likely pending sample finish)
- correct material clampcard
- 7075 aluminum pommel
- clocking pins
- threaded rod for assembly
- our steel replica covertec
BUNDLE KIT - $600
This will be for those that want to make one purchase that includes both the FX and Static hilt.
This would include:
1x main FX hilt (as described above)
1x Main static hilt (as described above)
1x Allen key for FX blade retention screw
Both hilts shipped in the single box, Civilized Hero packaging
FX Kit
Fully clockable booster and pommel.
Primarily Carbon Steel Construction
Spring Loaded Plunger System
Recessed PCB Holder
Asymmetric Grenade valleys.
This would include:
1x main hilt and all the 20 components (plungers, clamp card, pommel, etc.)
1x Box
1x Allen key
Price per kit is $375
Static Kit
This will be a non installable version representative of the materials and construction of the original prop.
This would include:
1x main hilt and all the 16 components
1x Box
1x Threaded Rod
Price per kit is $200
View attachment 1919040View attachment 1919041
View attachment 1919042View attachment 1919043
Awesome! Has a timeframe for placing orders been set? I know there is still a bit of time before this gets released
BUNDLE KIT - $600
This would include:
1x Box (with both hilts in it)
The current plan is that they will be available to purchase on May 4th, and be in the hands of the customer by the 20th anniversary of Episode 3, May 19th. Of course this mainly depends on the prototype and any possible snags along the way that may present themselves.
BRRogers RoninSabers
In reviewing the updated description for the static, the materials list doesn’t include copper. Does the mean the upper neck will painted? What will its base material be?
Thanks.
I had written materials representative of the original prop- which is admittedly vague. Sorry about that.
I have also updated the materials in the post to have more clarity
