That is correct. Once i get the prototypes I will test this, but the design intent was to keep the same installation.So if I were to get my current geonobi installed the kit wouldn’t affect the installation right? The only different install wise would be to use a 7/8 blade?
Not yet, not sure you are aware but Saberbay will stop operations shortly. However the upgrade project will continue and I will be handling it as originaly planned. There is just a slight delay while Saberbay gets things sorted out.Any eta when you'd possible have the prototype in hand?
We are good, we are just figuring out the details but this project is still ongoing.Yeah, I had heard and was worried as to your partnership with him too. Thanks for keeping us posted!
They are secured by the 3d printed chassis, you slide it out from the front side and they fall inside the hilt.Silly question, but what is the best way to remove/replace the stock red buttons from the hilt?
Yes the cost is firm.Understable about the finished! Sounds like an opportunity to buy some bras black and try a go at weathering. Is price still at $75?
None. You could recycle an installed chassis if you wish.Just to confirm, there will be no parts used from the original Geonobi saber?
