Hello everyone,
First of all, the kits are now live on my website:
Supergreen props, high quality movie inspired props for the collectors
supergreenprops.com
I have put a sufficient number of kits to cover every one from the list and kept a few on hand if anyone from the list misses out from some reason, you can PM me and I'll work with you privately. Everyone from the list will get his kit as always
let me list everyone that didn't yet get a kit to make sure you get the notification first,
Storm lmakeltraln Ryan Clinton OdiWan72 DarthWilder Pedro kurtyboy MarcoCazares Jamesfett thd9791 Hirohawa mgoob redbutton bobasfett LewisD seven ALLEY dkraude
alright, now, the kits are very easy to put together, I have writen a small explaination directly on the website page, but, here is a more detailled explanation with photos
First thing is, you need to disassemble your speargun as basically explained here:
The guitars are gorgeous my friend!! But despite the unexpected fever (more cowbell!!) some of us NEED these parts! Sadly, years from now there will be people who regret not jumping on this. :D
www.therpf.com
After the back of the speargun is removed, the (blue) barrel tube should be cut flush in the back and at a max length of 13.8cm in the front.
now, two things can happen if by any weird chance, you have a crazy variation. we never know with vintage stuff.
1- Check if the gears fit around your barrel.
maybe you got a weird version with a slightly larger barrel tube, in this case, the gears might not fit on it, no worries, the kit will still work perfectly if you cut the front barrel completely!
2- check if the small cylinder at the back of the muzzle fit inside your barrel.
In the hypothetical case that you have a thinner barrel, the muzzle base might not fit inside your barrel tube, you can cut the barrel a bit shorter in a way it can still be used to guide the back gear and a portion of the front gear, do not cut it completely if the gears fit around the original barrel.
alright, this was just for the weird Nemrods out here. let's hope that the kits will fit on all of your pistols. But again, if they don't, no worries, the kits will still work well!
Alright, now, here is everything you should have:
I have cut the bolt on the front of the threaded rod shorter (inside) as this blaster is a bit front heavy by detault. Take the end of the threaded rod that is longer, it can be recognized also by the small portion of untreaded bolt visible:
slide the cone part on the bolt and thread the washer to the bolt, they will stop at a proper depth with some threads visible in the back.
Insert that assembly into the barrel from the back of the gun.
Now, you'll see that one of the gears has a small recess in the front, this one goes in the front of the barrel, it assembles with the muzzle:
Dry fit together the two gears and the barrel and slide them on the speargun's cut barrel.
Then, just thread the muzzle to secure everything together. Make sure to align all the parts to your liking when the assembly is almost tightened. The front sight needs to be glued on the barrel in the appropiate flat spot milled in the front.
and here we go!
The variation "No V8 cone" doesn't include the large back cone part so you can use instead your vintage visible V8 engine kit plastic part. The back washer is still included to thread on the main threaded rod. Please be aware you'll need to drill a 13mm or 1/2" hole in your V8 cone to accomodate for the washer part. I don't know how solid the plastic part is, maybe it will be a good idea to use some kind of metal tube or stack of washers inside the V8 part to support it.
there you go guys, I hope you'll like the kits and I'm looking forward to see the first finished Relbys!
don't hesitate to reach out if you have any questions
cheers
