I have this secret plan to drill a little hole in the back of a resin V8 part. The trigger is held in place by a hinge pin and the rod that reaches into the canister and pulls the piston. Without it, the trigger can flop around. I guess you can glue the trigger itself in place, now that I think about it. I was just going to affix the rod inside the cap...
this reply went haywire, and I need to go back to my drawings lol
I think the best will be a handheld metal saw. the most important part is to be a bit flush in the back. If you are a bit too short in the front, it's not a big deal at all!What would be the easiest way to cut the blue barrel tube for someone without much in the way of tools and equipment? I do have a Dremel, but that’s it. Would a Dremel cutting bit work? Thanks!
good question! I don't think that ALL the greeblies are identified yet on that blaster, if I'm not mistaken.I have to admit I don’t know a ton about the greeblies on this blaster.
Maybe I missed it, somewhere in this thread, but can someone list / map the greeblies needed to complete a full build?
A dremel reinforced cutting disc will work. Here’s how I would do it (2 ways)What would be the easiest way to cut the blue barrel tube for someone without much in the way of tools and equipment? I do have a Dremel, but that’s it. Would a Dremel cutting bit work? Thanks!
