Limited Run Batman 89 Speargun Kits
Mine was waiting for me on my doorstep when I got home last night. I can't say enough good things about this kit. Spectacular care and craftsmanship has been put into this kit. It's absolutely outstanding!
My ‘89 build next to the SD v2. My build is only 85% done. Forgive the no trigger.
Haven’t seen anyone else post a finished gun besides Valor.
Here’s mine. I made a few adjustments and customizations. I wanted it to look a little more accurate with the connection and the ‘89 style Phillips screws on the hub. I also heightened the hub a bit. A couple things here and there. I know what you’re thinking: “Nightwing, you can see the connection between the 2 cylinders.” True. But you can see it on the original 2 part prop. Also, my connection may look like it doesn’t stick out as far as the original prop does, but the cylinder it sits on slides up about a half inch when it’s in 2 parts giving it that appearance on the original.
I hope you like it. Next kit I’m working on will be the Returns version. Stay tuned.
