ObscureReferenc
Active Member
Will you be making the brackets that hold the shroud together? And if so, can I be added to that list?
Unfortunately we are sold out of the shroud sets, uncertain if we are going to be able to have more made just yet.I would like to get in on the Shroud set.
I will be planning out the brackets shortly. They would be a "kit" though as any variation in trimming or what have you would affect the fit of the parts that require bending. Plan is to offer pieces that are precut with the right holes etc that the buyer could bend to fit their shrouds. Hope that makes sense?Will you be making the brackets that hold the shroud together? And if so, can I be added to that list?
No problem. Still interested so I will check back.Unfortunately we are sold out of the shroud sets, uncertain if we are going to be able to have more made just yet.
Makes total sense. Can't wait. Thanks again for your work on all of this.I will be planning out the brackets shortly. They would be a "kit" though as any variation in trimming or what have you would affect the fit of the parts that require bending. Plan is to offer pieces that are precut with the right holes etc that the buyer could bend to fit their shrouds. Hope that makes sense?
I see the lists have be updated. Here's a total of every Item Interested list I would like to be added to. "I'll take one of everything" hahaNo problem. Still interested so I will check back.
Also interested in
Grip
Magwell tabs
Barrel extension
Sling
Barrell vent (10 hole)
Stock (10 hole)
Extra mag base
I have added you to the lists for these parts.I see the lists have be updated. Here's a total of every Item Interested list I would like to be added to. "I'll take one of everything" haha
Grip
10 hole granade block
10 hole Barrel vent
10 hole Shoulder stock
Shroud set
Extra Mag base
Magwell tabs
Barrel extension
Sling components
Barrel extensions are in! Machined in steel! I will be sending every one on the primary list about payment etc., if there are any left over after then I will contact the waitlist people.
View attachment 1798950View attachment 1798951View attachment 1798952
Correct me if I am wrong dr_slurpee, but I believe these are intended to work with/fit on the stock WE M1A1 GBB barrels. The SnowWolf/Matrix barrels should already be the correct length/dimensions, however they do unfortunately lack the end-cuts.Hi do these fit the Snow Wolf/Matrix barrels and if so how?
Hi. How do they adapt to the PR?Barrel extensions are in! Machined in steel! I will be sending every one on the primary list about payment etc., if there are any left over after then I will contact the waitlist people.
