I have been working with a friend to create a number of high quality Pulse Rifle parts. They are a combination of known research and our own in order to dial in the parts. These will be limited run and no payments taken until the parts are in hand and ready to be packed and shipped.
Contact me to check on shipping, buy, or be added to the interest list.
Thompson Grip
View attachment 1759672View attachment 1759673
GBP£37.50 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
- Made to fit the WE-Tech Cybergun GBB M1A1 Thompson. (may fit others but unknown)
- Original model master incorporating a blend of the features of all the PR grips.
- Cast in high quality, impact resistant, black urethane resin.
- Base screw plug cast off a real Thompson grip screw.
- Interest List - vectorzero
- Interest List - maxhebus
- Interest List - Carrett
- Interest List - ObscureReferenc
- Interest List - AndyHoff
- Interest List - Cross57
- Interest List - Ram77
- Interest List - Available
Grenade Launcher Blocks
View attachment 1760463View attachment 1760464View attachment 1760465View attachment 1760466View attachment 1760467
GBP£49.00 each plus actual postage from UK.
- Created based on photos/research from the original parts, information from "BugStomper"/Pulserifle.net, and known measurements.
- Solid machined aluminum, cut from aircraft alloy billet, bead blasted finish.
- 8 Hole version is 72mm tall, 38mm wide, 25.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
- 10 Hole version is 72mm tall, 38mm wide, 13.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
- Holes for grub screw 2.5mm dia, ready to tap for M3 (or you can drill larger for a different size)
8 Hole Block:
- Interest List - Bacta
10 Hole Block:
- For Sale Now - Carrett
Barrel Vent
View attachment 1759932View attachment 1759933
GBP£94.00 each
plus actual postage from UK. Tracked shipping to the US GBP£20.00 (combined shipping would be quoted separately)
- Created based on information from "BugStomper"/Pulserifle.net
- Made from accurate 40mm square mild steel tube with 3mm wall
- Matching material and specs based on first hand research at Bapty
- Inner Diameter of the barrel ring is 19mm
- Milled and welded professionally
8 Hole Vent:
- Bacta - PAID and SHIPPED
10 Hole Vent:
Shoulder Stocks
View attachment 1759930View attachment 1759931
GBP£94.00 each
plus actual postage from UK. Tracked shipping to the US GBP£23.00 (combined shipping would be quoted separately)
8 Hole Stock:
- For Sale Now - Available
10 Hole Stock:
Shrouds
GBP£375.00 per set
plus actual postage from UK. Tracked shipping to the US GBP£29.00 (because of some logistics we cannot combine shipping these with other parts)
These will be sold/shipped as they are completed/ready based on the order of the interest list, no money taken before hand.
- Based on photos of aluminum hero shrouds and first hand research at Bapty (cleaned up to be made straight and symmetrical)
- High quality professionally made aluminum-filled, fiberglass shrouds, and mag butt caps.
- Uniform thickness around 3mm, STRONG, light weight.
- Comes untrimmed, with trim lines molded in for tight fit to a Thompson and SPAS cage allowing for individual adjustment for fit.
- Open access at the top, between the upper 'handles' (track along the top) for you to fit as strong and light a U-channel as fits your build. This allowed us to keep the thickness uniform, reduce cost and weight.
- Interest List - Joatrash
Extra Mag Bases
Additional Mag Bases available for anyone wanting to have extra mags on hand for their Pulse Rifles. These are the same as what is included with the Shroud Sets.
GBP£36.00 each
plus actual postage from UK. Tracked shipping to the US GBP£10.00
- maxhebus - PAID and SHIPPED
- treeboar - PAID and SHIPPED
- vectorzero - PAID and SHIPPED
- For Sale Now - Cross57
- For Sale Now - Ram77
Magwell Tabs
Milled from aluminum like the originals on the hero with bead blasted finish.
View attachment 1780284View attachment 1780285View attachment 1780286
GBP£22.00 per pair
- Designed to match from photos and reference first hand research at Bapty
- Come with correct rivets (we recommend cutting the rivets off and gluing the tabs and rivets to the shrouds as regular rivet installation can put a lot of stress on the fiberglass and gel coats)
- For Sale Now - Carrett - PAID and SHIPPED
- For Sale Now - Bacta
- For Sale Now - Xhiwar
Barrel Extension
Being produced now!
View attachment 1798954View attachment 1798955View attachment 1798956
GBP£24.00 each
- Jim - PAID and SHIPPED
- MooseF - PAID and SHIPPED
- DarthWilder - PAID and SHIPPED
- Moosh89 - PAID and SHIPPED
- barney five - PAID and SHIPPED
- CoCost - PAID and SHIPPED
- Harry Harris - PAID and SHIPPED
- userd1402 - PAID and SHIPPED
- ObscureReferenc - PAID and SHIPPED
- FullMetalJoe - PAID and SHIPPED
- turok96 - PAID and SHIPPED
- Waitlist - Carrett
- Waitlist - septic
- Waitlist - AndyHoff
- Waitlist - FokkerVF
- Waitlist - Cross57
- Waitlist - Ram77
Slings
Photo of the components being used to make the slings.
GBP£37.50 per sling
plus actual postage from UK. Tracked shipping to the US GBP£10.00 (combined shipping would be quoted separately)
- Made from screen accurate 8-band webbing
- Made from genuine period hardware.
- Jim
- DarthWilder
- mugatu
- nick-a-tron
- maxhebus
- maxhebus
- maxhebus
- Carrett
- ObscureReferenc
- MooseF
