I have been working with a friend to create a number of high quality Pulse Rifle parts. They are a combination of known research and our own in order to dial in the parts. These will be limited run and no payments taken until the parts are in hand and ready to be packed and shipped.
Contact me to check on shipping, buy, or be added to the interest list.
Available Now!
Thompson Grip
View attachment 1759672View attachment 1759673
GBP£37.50 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
- Made to fit the WE-Tech Cybergun GBB M1A1 Thompson. (may fit others but unknown)
- Original model master incorporating a blend of the features of all the PR grips.
- Cast in high quality, impact resistant, black urethane resin.
- Base screw plug cast off a real Thompson grip screw.
10 Available:
- Jim - PAID and SHIPPED
- Alien War Doug - PAID and SHIPPED
- CoCost - PAID and SHIPPED
- asoncsm101 - PAID and SHIPPED
- Hirohawa
- FokkerVF - PAID and SHIPPED
- Available
- Available
- Available
- Available
Grenade Launcher Blocks (Prototypes)
These prototypes were made using older information that was available, minor changes were made to the final versions. Added side by side photos for comparison.
View attachment 1759684View attachment 1759685View attachment 1759939View attachment 1759940
GBP£39.00 each
- Created based on photos/research from the original parts, information from "BugStomper"/Pulserifle.net, and known measurements.
- Solid machined aluminum, cut from aircraft alloy billet, bead blasted finish.
- 8 Hole version is 70mm tall, 37mm wide, 25.5mm thick, shotgun barrel hole is 24mm dia., the mag tube cavity in the back is 25mm dia.
- 10 Hole version is 70mm tall, 37mm wide, 13mm thick, shotgun barrel hole is 24mm dia., the mag tube cavity in the back is 25mm dia.
- Holes for grub screw 2.5mm dia, ready to tap for M3 (or you can drill larger for a different size)
1 of each Available:
- 8 Hole - PAID and SHIPPED
- 10 Hole - PAID and SHIPPED
Updated with minor changes from our prototypes
View attachment 1760463View attachment 1760464View attachment 1760465View attachment 1760466View attachment 1760467
GBP£49.00 each plus actual postage from UK.
- 8 Hole version is 72mm tall, 38mm wide, 25.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
- 10 Hole version is 72mm tall, 38mm wide, 13.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
10 of each Available:
- 8 Hole - Jim - PAID and SHIPPED
- 8 Hole - DarthWilder - PAID and SHIPPED
- 8 Hole - Harry Harris - PAID and SHIPPED
- 8 Hole - Alien War Doug - PAID and SHIPPED
- 8 Hole - barney five - PAID and SHIPPED
- 8 Hole - ObscureReferenc - PAID and SHIPPED
- 8 Hole - userd1402 - PAID and SHIPPED
- 8 Hole - Available
- 10 Hole - DarthWilder - PAID and SHIPPED
- 10 Hole - Moosh89 - PAID and SHIPPED
- 10 Hole - barney five - PAID and SHIPPED
- 10 Hole - ObscureReferenc - PAID and SHIPPED
- 10 Hole - asoncsm101 - PAID and SHIPPED
- 10 Hole - Space Jockey - PAID and SHIPPED
- 10 Hole - Available
Barrel Vent
View attachment 1759932View attachment 1759933
GBP£94.00 each
plus actual postage from UK. Tracked shipping to the US GBP£20.00 (combined shipping would be quoted separately)
- Created based on information from "BugStomper"/Pulserifle.net
- Made from accurate 40mm square mild steel tube with 3mm wall
- Matching material and specs based on first hand research at Bapty
- Inner Diameter of the barrel ring is 19mm
- Milled and welded professionally
- 10 Hole - eethan - PAID and SHIPPED
- 10 Hole - FokkerVF - PAID and SHIPPED
- 10 Hole - CoCost - PAID and SHIPPED
- 10 Hole - OCD is me - PAID and SHIPPED
Shoulder Stocks
View attachment 1759930View attachment 1759931
GBP£94.00 each
plus actual postage from UK. Tracked shipping to the US GBP£23.00 (combined shipping would be quoted separately)
Shrouds
Production sample, only lightly buffed, more buffing will give an even brighter look.
GBP£375.00 per set
plus actual postage from UK. Tracked shipping to the US GBP£29.00 (because of some logistics we cannot combine shipping these with other parts)
These will be sold/shipped as they are completed/ready based on the order of the interest list, no money taken before hand.
- Based on photos of aluminum hero shrouds and first hand research at Bapty (cleaned up to be made straight and symmetrical)
- High quality professionally made aluminum-filled, fiberglass shrouds, and mag butt caps.
- Uniform thickness around 3mm, STRONG, light weight.
- Comes untrimmed, with trim lines molded in for tight fit to a Thompson and SPAS cage allowing for individual adjustment for fit.
- Open access at the top, between the upper 'handles' (track along the top) for you to fit as strong and light a U-channel as fits your build. This allowed us to keep the thickness uniform, reduce cost and weight.
20 sets will be available
- mugatu - PAID and SHIPPED
- abaddon - PAID and SHIPPED
- krithargus
- asoncsm101
- MooseF - PAID and SHIPPED
- Johnnyfl - PAID and SHIPPED
- JLinNY
- holto
- FullMetalJoe
- Available
Magwell Tabs
Milled from aluminum like the originals on the hero with bead blasted finish.
View attachment 1780284View attachment 1780285View attachment 1780286
GBP£22.00 per pair
plus actual postage from UK. Tracked shipping to the US GBP£10.00
- Designed to match from photos and reference first hand research at Bapty
- Come with correct rivets (we recommend cutting the rivets off and gluing the tabs and rivets to the shrouds as regular rivet installation can put a lot of stress on the fiberglass and gel coats)
10 sets available
- DarthWilder
- DarthWilder
- userd1402
- Moosh89
- barney five
- barney five
- FokkerVF
- Johnnyfl
- Available
- Available
Coming Soon!
If you would like to be added to the interest list for any of these I will create a list and those people will have first opportunity to buy when available.
Slings
Photo of the components being used for the slings.
GBP£37.50 per set
plus actual postage from UK. Tracked shipping to the US GBP£10.00 (combined shipping would be quoted separately)
- Screen accurate 8-band webbing
- genuine period hardware.
10 will be available
- Jim
- DarthWilder
- mugatu
- Available
- Available
- Available
- Available
- Available
- Available
- Avail
