Ha, please tell us more about the replica SPAS cage!Here are some pics showing a shroud trimmed just to the guides and how it fits on a replica SPAS cage.
I realize I'm very late to the party, and I see there's a wait list, but if you could please add me to the queue for a set of shrouds I would be eternally grateful. Also, I'd like to buy a 10-hole barrel shroud, as well. Thank you!I have been working with a friend to create a number of high quality Pulse Rifle parts. They are a combination of known research and our own in order to dial in the parts. These will be limited run and no payments taken until the parts are in hand and ready to be packed and shipped.
Contact me to check on shipping, buy, or be added to the interest list.
Available Now!
Thompson Grip
View attachment 1759672View attachment 1759673
GBP£37.50 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
10 Available:
- Made to fit the WE-Tech Cybergun GBB M1A1 Thompson. (may fit others but unknown)
- Original model master incorporating a blend of the features of all the PR grips.
- Cast in high quality, impact resistant, black urethane resin.
- Base screw plug cast off a real Thompson grip screw.
- Jim - PAID and SHIPPED
- Alien War Doug - PAID and SHIPPED
- CoCost - PAID and SHIPPED
- Available
- Available
- Available
- Available
- Available
- Available
- Available
Grenade Launcher Blocks (Prototypes)
These prototypes were made using older information that was available, minor changes were made to the final versions. Added side by side photos for comparison.
View attachment 1759684View attachment 1759685View attachment 1759939View attachment 1759940
GBP£39.00 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
1 of each Available:
- Created based on photos/research from the original parts, information from "BugStomper"/Pulserifle.net, and known measurements.
- Solid machined aluminum, cut from aircraft alloy billet, bead blasted finish.
- 8 Hole version is 70mm tall, 37mm wide, 25.5mm thick, shotgun barrel hole is 24mm dia., the mag tube cavity in the back is 25mm dia.
- 10 Hole version is 70mm tall, 37mm wide, 13mm thick, shotgun barrel hole is 24mm dia., the mag tube cavity in the back is 25mm dia.
- Holes for grub screw 2.5mm dia, ready to tap for M3 (or you can drill larger for a different size)
- 8 Hole - PAID and SHIPPED
- 10 Hole - PAID and SHIPPED
Updated with minor changes from our prototypes
View attachment 1760463View attachment 1760464View attachment 1760465View attachment 1760466View attachment 1760467
GBP£49.00 each plus actual postage from UK. Tracked shipping to the US GBP£16.00 (combined shipping would be quoted separately)
10 of each Available:
- 8 Hole version is 72mm tall, 38mm wide, 25.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
- 10 Hole version is 72mm tall, 38mm wide, 13.5mm thick, shotgun barrel hole is 25mm dia., the mag tube cavity in the back is 26.5mm dia.
- 8 Hole - Jim - PAID and SHIPPED
- 8 Hole - DarthWilder - PAID and SHIPPED
- 8 Hole - Harry Harris - PAID and SHIPPED
- 8 Hole - Alien War Doug - PAID and SHIPPED
- 8 Hole - barney five - PAID
- 8 Hole - Available
- 10 Hole - DarthWilder - PAID and SHIPPED
- 10 Hole - Moosh89 - PAID and SHIPPED
- 10 Hole - barney five - PAID
- 10 Hole - Available
Barrel Vent
View attachment 1759932View attachment 1759933
GBP£94.00 each plus actual postage from UK. Tracked shipping to the US GBP£20.00 (combined shipping would be quoted separately)
- Created based on information from "BugStomper"/Pulserifle.net
- Made from accurate 40mm square mild steel tube with 3mm wall
- Matching material and specs based on first hand research at Bapty
- Inner Diameter of the barrel ring is 19mm
- Milled and welded professionally
- 10 Hole - eethan - PAID and SHIPPED
Shoulder Stocks
View attachment 1759930View attachment 1759931
GBP£94.00 each plus actual postage from UK. Tracked shipping to the US GBP£23.00 (combined shipping would be quoted separately)
Coming Soon!
If you would like to be added to the interest list for any of these I will create a list and those people will have first opportunity to buy when available.
Shrouds
Production sample, only lightly buffed, more buffing will give an even brighter look.
GBP375.00 per set plus actual postage from UK. Tracked shipping to the US GBP£29.00 (combined shipping would be quoted separately)
These will be sold/shipped as they are completed/ready based on the order of the interest list, no money taken before hand.
10 sets will be available
- Based on photos of aluminum hero shrouds and first hand research at Bapty (cleaned up to be made straight and symmetrical)
- High quality professionally made aluminum-filled, fiberglass shrouds, and mag butt caps.
- Uniform thickness around 3mm, STRONG, light weight.
- Comes untrimmed, with trim lines molded in for tight fit to a Thompson and SPAS cage allowing for individual adjustment for fit.
- Open access at the top, between the upper 'handles' (track along the top) for you to fit as strong and light a U-channel as fits your build. This allowed us to keep the thickness uniform, reduce cost and weight.
- Jim
- JLinNY
- DarthWilder
- Harry Harris
- mugatu
- Moosh89
- Space Jockey
- CoCost
- prev
- abaddon
- Waitlist - userd1402
- Waitlist - Cpl Potter
- Waitlist - barney five
Slings
Photo of the components being used for the slings.
10 will be available
- Screen accurate 8-band webbing
- genuine period hardware.
- Jim
- DarthWilder
- mugatu
- Available
- Available
- Available
- Available
- Available
- Available
- Available
I stated I wanted one on Facebook...a bit obsessively, Am I still in over flow? F.Scott McKownThe shrouds will have trim guides that will help people get close to fitment then they can finesse things as needed. Here are some pics showing a shroud trimmed just to the guides and how it fits on a replica SPAS cage. The guides get you close without having to guess and then you can fine tune it as needed. Also the "horn" in front of the GL trigger is made longer so it goes up tight to the SPAS cage so you can go with an idealized look or trim it back with the gaps that many of the hero shrouds had.
View attachment 1764012View attachment 1764011
On Facebook? I can certainly add you to the overflow for the shrouds.I stated I wanted one on Facebook...a bit obsessively, Am I still in over flow? F.Scott McKown
