Walking Dead Rick Jacket
That would be great, thank you.
Hey man so good news, I found the exact material for ya, just go to your Joanns physically first before you try ordering online!
Thanks man, you're the best. I'll order the dye and get the shearling, then I will show photos of the finished product.
I just checked and this shearling is a hot property. Only one store has any left and there is only 8 left. But I know this will be worth it.
Alright! It’s here and it’s looking nice! The lining has been removed from the jacket making probably the most flexible and comfortable jacket I’ve ever worn! Also the collar has been changed to the more accurate UGG shearling if not identical. Now all that’s needed is to dye the inside of the jacket to match the outside and we’ll be golden!
If you have any requests or questions I’d be glad to answer and fulfill them!
  • FullSizeRender.MOV
    62.4 MB
that looks incredible!
this is making me want to buy another WSL jacket, that looks incredible.
Here’s some pictures for you guys
Before-
After-
I think the reason removing the lining from the jacket removes the squared shoulders is because it makes the jacket very stiff and holds the shoulders up. Removing it cause the jacket to be loose and more flexible.
Didn’t they remove the lining on The actual UGG jackets in the show??
im sure that removing the lining will help with the shoulders to some degree but every replica has a fundamental issue due to the cut of the jacket itself. however if removing the lining helps with that issue its a nice side effect for people looking to alter a jacket like the show did.
