Tombstone Val Kilmer / Doc Holliday Costume
Thank You CooperRevan Trench coat?? Do you mean the Inverness coat/cloak??
Just to let you know when you send a post and it says "OOPs we ran into problems" it actually sends. Don't try sending it again or else you will and it will double post. After you send it just refresh your screen and you will see it posted.
One of the phone apps I use for this odd hobby is Golden Ratio Face App. It does an incredible job at facial comparison even though that was not its intended purpose. It is super buggy so I can't recommend loading it but the results are very consistent. Anything over 40 and you have the same bone structure. Anything over 50 and you have the same general look (glance and you would assume it was someone you recognize). Over 60 percent (especially before disguise effects are added) and you are guaranteed to look great when in costume and have a great chance of upping that number with effects makeup. Over 70, you look like the person but maybe at a different pose, different age, weight etc. but still convincing to most viewers. 85 and you would fool your own mother. 95 is the max, which points out how the numbers below that are in reality higher. Two identical pictures can run as low as 95. I have had multiple cosplays that started at 50 and ended at 80 plus with effects kit and the right pose (the angle you most look like the character). Here is yours with no effects:
One of the phone apps I use for this odd hobby is Golden Ratio Face App. It does an incredible job at facial comparison even though that was not its intended purpose. It is super buggy so I can't recommend loading it but the results are very consistent. Anything over 40 and you have the same bone structure. Anything over 50 and you have the same general look (glance and you would assume it was someone you recognize). Over 60 percent (especially before disguise effects are added) and you are guaranteed to look great when in costume and have a great chance of upping that number with effects makeup. Over 70, you look like the person but maybe at a different pose, different age, weight etc. but still convincing to most viewers. 85 and you would fool your own mother. 95 is the max, which points out how the numbers below that are in reality higher. Two identical pictures can run as low as 95. I have had multiple cosplays that started at 50 and ended at 80 plus with effects kit and the right pose (the angle you most look like the character). Here is yours with no effects:View attachment 1710320View attachment 1710321
I did a test and it came out 100 % Neanderthal !
Yes, close for sure; the nose is, of course, a problem in make-up. It's easier to modify when small going toward a bigger one.
The contrary is hard to do. Make-up and shadows are your best bet at that time.;)
Sweet *****, I’m 62% to 67% :) I will take those percentages to looking like Val every day of the week :) This just made my day….. THANK YOU!
