I'll grant you that Easter egg...HAH! And look what I just caught in my own photo, another Easter egg! Those little devils!
Thanks for the tip regarding the foam inserts. I understand how the inserts are put in and the wall bend but I've had things that snap fit into place before that have gone in easier than others, it was for my own peace of mind to file them down a tad. Still fit perfectly but easier to put in on mine.It's intended to bend that way, that's why the back wall is molded so thin--if it didn't bend, there would be no way to insert the dividers.
Here's Andrew Stockdale on Instagram showing the correct technique (also shown in the manual):
Also, as to the shape of the battery compartment, it's flat on top and then curves on the forward wall, and the bottom of the door compartment is curved to match:
Finally, here are the photos posted on Fleet Workshop showing the foam inserts holding the scanner snugly:
What is it?HAH! And look what I just caught in my own photo, another Easter egg! Those little devils!
What is it?
Oh wow! OK. Thanks!
I'm afraid we will have to ask for your geek card now.Oh wow! OK. Thanks!
I don’t believe the medical badge is canon from the original series. Dr. McCoy wore a blue shirt with the sciences badge. I may be wrong though.
Nurse Chapel had oneI don’t believe the medical badge is canon from the original series. Dr. McCoy wore a blue shirt with the sciences badge. I may be wrong though.
Nurse Chapel wore the red cross badge.I don’t believe the medical badge is canon from the original series. Dr. McCoy wore a blue shirt with the sciences badge. I may be wrong though.
Not only that, but (I believe) in the first two seasons, the red cross was cut out of felt and glued on top of a sciences insignia. Eventually they made her one custom embroidered like the others though, I think in the 3rd season. Someone can correct me if I'm off on the timing.Nurse Chapel wore the red cross badge.
I guess my follow up question is since Dr. McCoy was the head medical officer on board, shouldn't he wear the medical badge?I don’t believe the medical badge is canon from the original series. Dr. McCoy wore a blue shirt with the sciences badge. I may be wrong though.
Correction: I was wrong, it is canon. Who knew?
(Apparently, just about everyone!)
Is that the entire blog?Update on the blog from Chris B on U.S. sales:
Chris Barnardo May 22, 2025 at 4:21 pm![]()
In the US our US customers will be buying from Amazon US. The 1,200 units of US stock is in our Chicago warehouse and is scheduled to be picked up on Monday next week to be moved to Amazon and we the second air shipment is scheduled to arrive in the US next week. So things are moving now.
I guess my follow up question is since Dr. McCoy was the head medical officer on board, shouldn't he wear the medical badge?![]()
LINK: The Wand Co Tricorder BlogIs that the entire blog?
I appreciate all the images and specific verifications that "item x" will fit in the lower compartment. But can someone provide specific measurements? Without one in-hand, I assume the following measurements of the lower compartment would handle most of our questions; inside width (without dividers installed), inside back height, inside front height, inside top (back-to-front) depth, inside bottom depth, and wall thickness. I would give extra points for bottom radius curvature, top radius curvature, and front face to back face angle.
