cavx
Master Member
Amazing. Cant wait!
Me too
Amazing. Cant wait!
Interested. Thank you!
OK crunch time.
This tube bag should be $350USD + shipping.
Shipping to the US is based on weight. I am not sure when Australia Post changed this (it used to be based on cubic volume or weight and you payed the higher amount) and the quote I got today for upto 3KG was really good.
Now to kick this off, I am going to buy the 5, 800mm x 800mm sheets of 4.5mm ABS and make one bag up. Based on how it turns out and what your feedback is, will determine the next step for this project. I am hoping to get either 0.6 or 1.0mm clear for the ends.
Not 100% sure. It would be good to do that.Home stretch! Are you thinking you'll send them assembled now since volume isn't a concern?
This is amazing and I am still in FYI, I am located in Germany
If you are on the list? Sure thing.
The only catch with the EU is that they do charge an import fee for anything over 150euro. And this is payable by you.
Sent from my CPH1701 using Tapatalk
It is a percentage of the listed price.Yeah, I know. Every time an expensive hassle for me at the customs office as most cool things come from out of EU
Gesendet von iPhone mit Tapatalk
Apply heat and suction over a tool and you get awesomeness.Plastic!
This is 4.5mm thick and I have 6 sheets. https://uploads.tapatalk-cdn.com/20180608/794a2aa168e5365750736d6acf34a76f.jpg
Yes they are and on the earlier version, I did have a shorter handle bar. The problem is because I am vacuum forming, there are things it just won't do without causing other issues. So I had no choice but to extend the bar to edges. This does increase stability dramatically. Another thing I have done is to add what is called a return edge. This also helps with strength.I hope I don't sound rude, but arent the handles supposed to start out skinny and get thicker? Is your way just a design choice for better stability?
https://img.thngs.co/preview/x480/t...2015/60323280-ee81-4e41-bdcf-3b7250d95ba1.jpg
So I modded the body to allow the lids to open further.Based on this screen grab, the body can not be 180 degrees as my lids won't open up that far.
Thoughts? https://uploads.tapatalk-cdn.com/20180611/7a2d0281777dcec2dc697c8c7a19fd87.jpg
