@cavx are you doing anything to the end caps? They look too rounded to me.
Yeah, there are a few parts that I need to tweak and the end caps are one of them. The metal tool got hot and the plastic actually stuck during the pull. Apparently cooking oil is what I need (same principle as frying an egg) to help the plastic slip and not stick.
This is more of a proof of concept that -
A: That my vacuum former actually works for some big parts and deep pulls and
B: That this bag can be made from just 5 main parts. I'm sure my initial parts count was 13 or something, so this method has allowed me to re-design down to the 5 main parts.
So there is still windows to be cut from some clear, and based on how the handle recesses went, I will be having to form new ones. But these can be made from off cuts and do not require a full sheet of plastic.
I did the end caps individually using a full sheet per cap as a male tool. I think that if I went female tooling, I could make 3 caps at a time and actually get a better result from each part as I will be drawing into the tool, not pulling over it. With female tools, webbing between parts IS NOT an issue and as the plastic cools, it shrinks away from the tool, not onto the tool like it does with a male tool.
Of course, there is still temperatures and heating times to work out. This is 4.5mm plastic and each part took about 3 minutes to heat to a formable state. At times, I may have gone too hot as hearing creaks and groans during the pull can be a bit unnerving with this thickness and not enough heat.
The very first test on this rig a few years ago snapped a 5mm sheet of Perspex in half because it was not hot enough.
So here is where I am up to on the new tool for the end caps.I will make a new tool in the next few days and hopefully we have not only a better shape, but the ability to pull 3 at a time and not just one.
Looking awesome, enjoying watching this come together...
Thank you. Yeah it will be cool to see it do what it does in the movie.Awesome work! The smart glass idea sounds like a good option :thumbsup
Thank you.Awesome work! Super late to this thread. Is there any way I can get in on this?
