hey guys,
here is a relatively big update,
All of the small parts for the run are done, "just" the main body tubes to finish now.
Knurled back caps are all done, that was quite a workout! but they turned out nice, so I'm happy I managed to do such a difficult part:
all the other parts, cores, motor couplers, "static" cores with rods, motor spacers, rods for the motorized versions:
those are spacers to center the motors inside the main tubes. The idea was to go as quick and cheap as possible, so I started with a 35x5mm tube that was close to the spec we needed. The exterior was turned down slightly to fit the tubes, the inside is very slightly too large for the motors, so a bit of tape will be necessary, basically like they did for the screen-used saber:
small jig made to turn the outside of the short tubes:
those are core/rods assembly for a "static" version i'll offer as well. it is built around two cores with two ball bearings to attach at the same position as the motor spacer would be attached under the clamp, mimic the weight of the motor and have a free spinning stainless steel rod at the emiter.
This will be a low number option and all the parts will come assembled already. Just needing the red button, glass eye, clamp and grips.
The final numbers for the run will be like this normally:
21x assembled motorized sabers: price to be determined (160-200€...)
9x static assembled sabers
13x motor ready kits (base kit with extra parts)
20x base kits
I'm keeping the base kit as is but am wondering if the stainless steel rod shouldn't be added to all versions (5€). But I don't want people to feel forced into buying more than what I first offered during the interest request.
I'm making several options available on top of the initial base kit offering to try to fill the need of each kind of builder/collector, and have tried to remain very affordable for all the versions, I hope everyone will find what they need when the release happen.
next update will be for the last part, the body tubes. Pretty difficult part, lots of cool processes and jigs for this one!
cheers all
