Kosh Play
Workin on some vents. I want the center to be open and debating if I will cast in rubber of silicone.
I want them to move around slowly and maybe puff out air. Also, I will see what one sculpt for both side vents look like.
I used drink cups for the rounding support on the sides. Once I have an anchor on the sides for the curve, I can tape aluminum to bridge the rest of it over.
Secretly I have been adding more n more to the body to make it rounded. Now that I have the side cup/support areas I can work on a true 3D model. The pic I used was at an angle, so recreate the angle, and then round everything off
The head piece and fun with a hole saw for the eye.
Then make the hole saw eye piece part o da FACE!!!
Now Kosh can ask, "who are you?"
who-who, who-who?
***CAUTION***Posted video has an F-Bomb
Used foil and stirrers to bridge gaps between sections and meet where I placed a plastic cup.
You can see the ink from the plastic bag that was the protective layer between FreeFormAir and the 5" ball I used to make the shoulders. I guess the bag's creators wanted them to leave a lasting impression on anything they touched. ;P
Kosh lookin more like Kosh.
Also, RedBulled to the bottom of the helmet where the aluminum was, I gave it wings
more terrible puns to follow
What ever happened to that crazy blackening out details for a 3D print ?
Just clean em up. Put some xtc 3D on them so the casting material doesnt get stuck in them, and I will have perfect stained glass
Broke down and did the left bib.
Originall was just gonna do two right bibs (one mirror image) but Dark Pope has a perfect shotbof the clearly larger left Bib.
Coated the bibs with xtc 3d. Couple of reasons why:
To make it stronger.
Less nooks and ridges to grab onto when demolding. I still want ridges and nooks, but no enough to tear it apart while de-molding.
I have also been purdy-ing up the other parts.
There is s thread about "idealized" props. Funny how sculpted stuff is full of assymetries and flaws that you debate over keeping for the sake of legit, street-cred vs a million year-old creature prolly wouldn't have such obvious flaws or imperfections in a suit designed to hide its identity vs would it care?
New part designation, the back pieces will be called "Scapulas' or "scaps."
Have you done a search on this forum for other
Kosh cosplay? I reasonably sure there were at least two others that did full costumes.
  • Wow
Reactions: JPH
I found a thread asking about fabrics and DarkPope's wunnerful thread with a ruler!!!
I can use a computer instead of my phone to search, but I feel like I already have what I need depending on how *perfect* I want the costume to be.
If you have any input or ideas I'd love to hear them.
I found an instructables website for 8-panel, 2 inch iris door templates.
Prolly gonna make the neck vents/slats out of aluminum using a bendable copper pipe as the lower ring on the inner body..
Am I missing any riddles to this quest?
No, far from it. You seem to have a plan that you are following and are perfectly capable when it comes to your costume. I meant more so as inspiration as you get further into it. I have no doubt when completed it will be a masterpiece. Do you plan to motorize the iris?
  • Like
Reactions: JPH
Thanks.
I think it will be okay. I have already taken some liberties at modifying it from the original. Edit : removed a second "already."
The iris will be motorized. I also want a sound and lighting system and hopefully a paint job that changes color as it moves. But all things in time.
I have a tendency to eat, sleep n breathe stuff til my brain is done. Then I pause and come back to it later.
I still have the bug for this project, I am trying to balance how I would do it, with how it was done, with how a million year-old would have done it.
I appreciate you following the thread, and once again, if you have any ideas,
Love to hear 'em
Spent the past few days reviewing reference pics and trying to make things slightly above the projected 37% accuracy.
Fighting the urge for perfect copy of asymetircal prop vs symmetry that seems pretty implied.
Lots of touchup. I like that I can sculpt with sanding, it is a slower process than clay, but with a rigid sculpt, I can sssllllooowwwllly cater it to the design I want. Harder to overshoot what you want.
I like applying the XTC with a pigment that stands out, it pools in cracks and makes peaks and valleys come out with gloss. I know, the stuff is getting pricey, and to sand off some of it seems wasteful, but a little goes a long way.
Also, thanks to TheDarkPope 's reference photos with a ruler, I can make templates for things like vent openings that are, atleast, a good 43% accurate.
You see this stuff on tv, and you get a rough idea of size, but the ruler really, really helps
The next step will be to add the Greens - the green, side thingys- so, I have been adding crap, then sanding/filing. Adfing more FreeForm Air, then sanding/filing.
Not very exciting, but the Greens will be based on what is already built, but if I build on crappy foundation, it compounds the inaccuracies.
Sand, add stuff, repeat
I will hold off on pouring stained glass sections out of Task16 until I get the sash part ready.
Task 16 is getting more n more pricey and it starts going bad once you open it.
