Has anyone found a blade plug for the Graflex 2.0 that is somewhat similar to the original bulb plog?
To those who have these Graflex's, are the grips made out of rubber or are they a hard plastic? I own a Parks MPP and had to change the grips to screen accurate hard plastic because Jeff supplied rubber grips which aren't correct.
Hard plastic! (Nice and sturdy for the screws for the esb/TFA grips!) and they are also curved to fit into the saber! To say the adhesive they have on them is strong is to put it mildly, so just take your time lining them up and make sure you have it set up for the right amount of grips/holes you want!
any issues with your red button?Got mine today. Super easy to put together, but it took me a while to figure out that the bottom half has to screw out.
I'm planing to replace the card with a gold one when I get the chance and I'll be getting Yoda's crystal chassis when he releases them.
It's my fist saber and I can't be happier with it.
I also swapped the edge connector for the gold plated one that wannawanga.com sells. I think it looks better.
Just had to file down the edges of the boards for the button, then I used some white-tac to stick the red caps temporarily in place.any issues with your red button?
I'm going to make them more permanent when I get around to doing the electronics.
Does the TFA version of the saber meant to have the ½” metalized tape for the Graflex clamp around the middle?
