Limited Run Graflex 2.0 and Crossguard saber run - sign up thread
I think it depends anh or esb? I just ordered the gold I like it!
- - - Updated - - -
Can or does any one know or have a list of needs to fill this thing with power? Minus the sound board I'll figure what I want later but I thought maybe some would have a graflex guts package to sell?
Glad to help. I ended up putting the second red button on tonight in place of the lens. I like being able to swap out parts so easily with this kit!
I can't wait to get mine so I can have a play around with everything, I'm pretty keen on making mine a TFA version, but anything could happen when it's in my hands haha
So it's that easy to swap out the red button and eye? I'm having a hard time deciding between ESB and TFA. Leaning towards TFA for my girlfriend's Rey costume, but having a functional button might be better.
Yes, they just screw in and out. Super easy.
I made one easy modification that others might be interested in. I have no plans to add electronics or sound to my saber, so I didn't want the speaker holes on the bottom.
I carefully traced the bottom plug on a piece of aluminum foil tape and then cut and adhered that foil sticker to the plug. Then I screwed in the bottom bracket and now have what appears to be a solid bottom plug for the Graflex 2.0.
attachment.php
http://www.therpf.com/attachment.php?attachmentid=495245&d=1435685753
I think your kobold has the wrong side facing outward?
I'm not sure if this is gonna turn out ok or if its gonna be worth the trouble... but... I bought a 2 cell bottom to make an end cap out of it and replace the current speaker hole cap. What do you guys think? it only cost $10.
  • Like
Reactions: MCM
Help please!! :O
Hi everyone this may sound like a stupid question but I am piecing together my hilt into the ESB version. I think I have messed up & have to rip off one of the grips hopefully before the adhesive dries.
So with regards to the grips there are six of them. There are 7 pre-drilled holes on the hilt which holes do the grips go into. I realise that one of the 7 holes will be missed but which one?
I realise it is not going to end up symmetrical.
You need to remove the screw on the clamp and unscrew the bottom half from the top. The other side has 6 holes for the ESB and TFA configuration.
Ohhh ok.... thanks for your help. Turns out I have completely botched it up & they are stuck on there. I am going to have to pull them off.
