Lambzilla
Well-Known Member
Thanks for the heads up, I will do it that way instead.
So, I retook the screenshots via the method RooBee said (thanks again) and the shots turned out much better than before. There's well over 200 images, so I had to split them into 2 albums. You can find them here:
01 - http://imgur.com/a/ArBah
02 - http://imgur.com/a/23lIt
When zoomed in on spreads/notes you can't get the whole thing in the shot, so I did top and bottom shots and was going to splice them together. Unfortunately, Nate's constantly moving around, so I wasn't able to that and have them match up (which is why there are so many images in the albums). I could fix them together in photoshop, but don't have the time at the moment, so hopefully the separate shots are enough, or if someone else wants to try manipulating them to fit together that would be great.
I also included the text of most, if not all, the notes since the script can be difficult to read. I was able to splice those together into one image when required and blacked out repeating text so it wasn't confusing. I think there were 2 pages that had drawings where a note was placed on top. The note makes it difficult to see the actual journal page, but I tried to get it as clear as possible (one has celtic knots, the other has lemurs). Unfortunately I couldn't get zoomed images of them.
The only thing left to mention is at the end of the journal were 2 blank spreads. That's as far as you could flip. If there's anything else let me know.
EDIT: I've also uploaded an album of just the spreads: http://imgur.com/a/1ge5G
