cha0tic
Active Member
Not sure if I can achieve that color or achieve it properly, I think better off saving that for a urethane spider. Sure I can make it silverish/greyish the spider but it won't look the same or have the same appearance as that spider does. At least I can't achieve this. Most patterns I see use a white/greyish type spider along for example brads flat webbing and spider symbiote suit.
Well I underestimated myself, started adding more sections to the gradient and this is what I have atm
Feel the spider is a bit bright, but this is just the rough draft. Will also be doing the same for the back spider. Will update once I'm done.
