Hi. Any updates or photos on this project? I'd really want to see the process. Any estimated arrival time? Thanks!!
Hi everyone,
Sorry I haven't given much news lately.
The earrings are going well. I'm finishing the assembly, but I just ran out of my gold solder today so the next few days I'll be working on finishing the stands (I've cut and sanded them, all I have left is installing the small pins to place the earrings) and start polishing. (I'll finish assembling the remaining one later.)
To take a look at my process:
- The brass fangs and the gold filled rings had already been cut and polished the last time
- I just tin each hook with my gold solder. I used a "Brazilian torch" which allows to obtain a very hot flame with a natural oxygen supply.
- I clean them for the first time in a hot bath of household vinegar and salt to remove flux and oxidation from the heat, then pass through a bath of sodium bicarbonate to remove the acidity from the part.
- I then assemble the piece. The silver ear studs are brazed with a silver paste (the solder in plate had a tendency to overflow). I turn each piece over and heat it again to make sure the solder is in good contact everywhere. As a flux, the best I've used is Firescoff, but it's still quite expensive and the bottle wears out very quickly. So I continued with the borax I already had
- Again cleaning in the baths and drying
Said like that, it seems easy but it's all quite tedious
I still have some work to do with the polishing, but I'm starting to see the end.
I can't say exactly when they will be finished yet but I hope to be able to release them in not too long.
Here are some pictures, and if you have any questions, do not hesitate. Thank you for following my project
Cheers,
