Got a bunch more done, mainly now the side docking rings.
Since this model has smooth sides and scribing the lines in just didn't work, and I didn't really try to add styrene panels to make it, I decided on just painting the lines in, to look like it was scribed.
Using the best reference pics I could find, along with Sean's perfect replica, did my best.
Mainly cut the shapes in the tape and painted along it.
Took 2 or 3 coats to look good.
After getting them all in, that I could at least see in pics anyways, I then cleaned up edges with an excto knife.
Then, went over it all with a watered down white.
I'll later on weather over top all this.
Not everything is completely correct. Some being because getting the tape in the tiny areas was quite tricky and some came out in a bit of an angle...so more weathering on those parts will help.
And the underside thats pretty much done. I'll look it over and decide it any area needs something more.
When I first painted it in 2009, I added some damaged spots with a soldering iron, but plently of it is either totally wrong, or close but a bit off.
So I just went ahead and weathernthose areas with the darkened damage anyways.
So now to just weather all the sides pretty much to get it as closes as I possible can.
I ordered the decals a few days ago, so hopefully will be here soon.
And the guns and dish....don't want to forget them.
