Chrisisall
Master Member
Server problem, please delete.
I was thinking about a light mist from a can. But I also tried a very watered down white over parts, and dabbing most up with a paper towel. Between both ways, I think it should work out.
I'll probably also mix up some paint and water down so its not all stright white.
Layers apon layers is what seems to really help as well.
Looking at how it was before I started here, already a ton of improvement.
Ill have to check on that.also instead of straight white you might try something closer to the base coat. Basically white, with a but of grey and tan added. You can also try those regular pastel/charcoal sticks (black, and brown and white mainly). You can find them cheap and you just scrap them with a knife to get some powder. Excellent method for doing the soot stains and dirtier areas
Yep, looking good for sure. Nice job with the paint chipping effect
Thanks. This is my first real time trying the chipping look. Trying to make it look as chipped as possible and not like a brush was randomly dabbing paint. A few came off that way a little, so I'll fix up those eventually.Your post came through and your paint job is looking good. Take your time as the painting is what makes the Falcon.
Just to clarify what I'm meaning, these tiny ones, since they couldn't be painted on. I'd read that it said stickers, but I do see it says water slides on this, which is probably better.I would stay with the paint as you are doing a super job on it, paint is better than stickers in my book anyways. I love how its turning out Great model work keep it going nice job
Yep, roughly the same scale JediMichaelJust to clarify what I'm meaning, these tiny ones, since they couldn't be painted on. I'd read that it said stickers, but I do see it says water slides on this, which is probably better.
I would imagine, despite the scale numbers being different, that if they both Falcons are around 19 inches long, these should be about the right size, or close enough for the MPC Falcon.
Cool. What I figured, just the two scale numbers were throwing me off and wanted to make sure.Yep, roughly the same scale JediMichael
J
