Limited Run Luke V2 liightsaber (Second Run) Sign up thread
Ok, this is too good to pass up. I'm in for ONE. Hopefully it will be easy to get in touch with whoever is doing longer clamp lever and circuit board thingy -- Roman is easy to find, so I'm good there. If anyone has contact info for the other needed parts, please post or PM me.
Post number one.
Mods, I hope I'm not stepping out of line here, but I hope this helps some of the other new members
Edit: If you are a n00b like me the following may not make much sense: "It will be your job to get a clamp, lever, and card. Slothfurnace will be did a run of cards. Roman has clamps, Roygilsing has the levers, and Trooper_trent has some awesome stencils"
Basically it says you will have to supply your own 1) Clamp 2) Lever 3) Card and 4) Stencil for weathering. I would search the web for a Graflex clamp with Roman, then a ROTJ v2 lever again on the web. For the card, maybe search "slothfurnace card" on the web. Finally, for the stencil (if desired) maybe search the Project Runs for Trooper_Trent.
I hope I am not breaking any rules here, just trying to contribute in some small way.
I'm so excited for this run and can't wait to get mine, but does anyone else think the reproduction isn't thick enough in the circled area?
http://wannawanga.com for levers
slothfurnace.com for the circuit boards
