JFcustom's FOAM files
Re: FOAM speed building files'n'tricks ►Cyberman & Dr.Fate◄ added
We will wait for that too =D
Thanks! I hope it looks good painted....always wanted a this helmet.
I can't wait to see your paint job!
I always wanted one of this too!
Thanks JC! Amazing file, I didn't change the scale but I needed to adjust the eyes in order to see! XD
Enviado desde mi GT-P3100 usando Tapatalk 2
Nice.....Your foam is softer..... I still have ridges where I made the cuts...I need to get better at making it rounder....
Re: FOAM speed building files ►Freedom & Landmate Gundams◄ in progress...
You work on landmate before the freedom ? Well... I will wait a loong time. :lol
Yes, mine is really soft, except for the crest, I made that one with a harder foam!
Thanks bill, I think leaving the card glued to the foam stiffens it up quite a bit, which sometimes helped and sometimes not. I think just using 80g paper would have been better for this purpose, keeping the stiffer card for templates
with the gundam files you say enough to make a bust so I presume they are sized for that purpose not for making into a costume JF?
I think the files are for costumes.
Sent from my GT-I8190 using Tapatalk 2
I talked about a bust, because I assume nobody would wear a gundam suit with no arms no butt and no legs...
About the size, for now files are randomly scaled. Let me check that...
Ok, so with its current ratio set at 300 this freedom bust would go to a 5'3" or 5'5" boy/girl.
At the end and for these same files, the scale factor should be raised up to 330 for a common 6' tall guy.
The landmate files are set to 70, that is already scaled for a 6' user.
Clever question ;)
Who here would have inquired too late about that ? Mmh ?
Well.... figured I've posted on the other ones I've done.... nice color choice....
Lol JF well I thought it be wise to ask before I start to try and build it other wise might be a bit disappointed if all I ended up with as a statue for my desk lol ;)
Durkness that awesome did you do that the last couple of days?
The previous color scheme was pink, purple and red... So before sharing it I pasted the color set of Durkness's build to seem more serious. :$
I got to that point recently... I started it 10 days ago...but, I am working on my Iron Bat and made the Dr. Fate helmet during the same time frame with little time to work on stuff. I don't settle very well on projects. The file doesn't have any details so it was more of a test run to see if it's capable of being something more, which it is.
My wife tried the helmet on after it was painted.... I should have left it your original color scheme.... :D Thank you sir for the file. It has easily become one of my favorite helmets and it's not done yet....
Has anyone ever put the fiberglass cloth and resin on the inside of it foam helmet. Would the resin melt the foam?
Soooo, I've just been kind of asking around for this, but what are the odds that you would do a foam pep file for the Juggernaut mask from DotA?
