Darth Africanus
Sr Member
Pleasure man glad you enjoying it!Great info guys
Alright y to continue with the time line
so Star Wars was a huge success and Darth Vader becomes an Icon
the Icon we all know and love
So a mold of the original ANH screen used helmet was molded
The Baker mold in the USA spawns a helmet cast used by Lucas film to promote star wars
Kermit Eller an employee of Don post studios don's the Vader suite wearing helmets from this mold
and the original screen used ANH helmet lands in the hands of a private french collector
Now in 1979 ESB production starts I believe
The Mold called the UK mold is still at the UK production studio Where ILM
makes most of the props for star wars if im correct
This UK mold is a exact copy of the original screen used ANH helmet
it has the three 3m apple tabs still on top of the mask crown
as well as much of the original details found on the Original screen used ANH helmet
small chin vent triangle etc
the Dome is also a copy of the ANH but there might have been
a cast made of the ANH dome modified by the ILM crew
and then Molded as the ESB/ROTJ domes
where this new modified dome was bit shorter in the skirt of the dome
the dome skirt was sanded smaller than the ANH dome skirt
and the center strip was made wider by a small amount than the ANH strip
and the ANH sharp widows peak was cut back/sanded to give it a flat look
and the Y crease of the ANH dome was left in the ESB dome only a little
and the indentation of the center strip as well
The mask came out and ANH mask out of the mold
the ESB crew cut out a wider and bigger chin vent by hand
so Prowse could see better and for air flow
the lenses were changed to a bronzish tinge clear
the mask was cleaned up some what made smoother,sharper etc
Below is an illustration to show what happened to get the new ESB helmet for Vader
Purple line is the widening of the center strip it was made marginal wider and softer
over the ANH strip
Red line was the dome skirt sanding it thinner
I believe the ESB dome was sanded abit shorter in the dome flange from the bottom
but Im in two minds personally that all movie domes were ANH domes with the
changes of the wider dome strip for ESB/ROTJ and the thinner skirt
as well as dome flare correction
Green is the dome flare was brought a bit more inward
it was brought more inwards on Vader's right side our left looking straight on
and then the wider bottom chin vent cut out on the mask
Sharp widows peak sanded/cut back and made flat
Further the ESB crew added a new dome mounting mechanism
on top of the mask crown and inside the dome
this mech was a PVC ring with a smaller diameter ring on top of the mask crown
and a larger diameter ring that fits over the smaller ring inside the dome
the mask also received a piece of Velcro on the forehead
with the connecting piece of Velcro inside the dome for a firmer dome mount
so the dome doesn't fly off like it sometimes did in ANH because of the flimsy 3m tab connection
Because of the new dome mounting mech the ESB dome was also more raised up and sat abit higher
over the nose of vaders mask the dome did not sit so low on vaders nose like in ANH
The tusks sensors on the end of the tusks for the mask remained the same as the ANH mask
only thing is both tusk sensors where silver not like in ANH where the left side one was half blackish
with splotched paint
the mesh inside the mask vent's also changed over ANH in the ESB helmet
and lastly the Mask and Dome was painted smooth with an automotive grade paint
mask was still an alternate color of gloss black and metallic gunmetal grey
only now in ESB it had a sort of polished showroom finish but not perfect finish was still orange peely etc
as well as the dome was painted in a gloss black automotive paint
polished smooth yet not perfect mirror shine smooth
had orange peel and defects in paint job
So the ESB helmet
below is the stunt mask it had a few major differences over the hero ESB mask that I will address
bit latter on
Bit to get the idea of what im taking about one can clearly see the ESB
round PVC dome mount
larger chin vent
etc over the ANH helmet
and new smooth paint job
Next I will post on the ROTJ helmet
But from here it is where things get tricky as I don't want to begin arguments !
So for the production of ESB a few helmets were cast from the UK mold for the production
so they started off ANH and were converted by hand to ESB by the crew as described above
im not sure how many helmets were made I can not say as I have not definitive information on this myself
But off these set amount of helmets made some become Hero helmets worn by Powse as seen in most of ESB
one becomes the blown Luke dark side cave helmet
One became the weird ANH mask / ESB dome helmet seen in the beginning of the movie when vader storms echo base
and one became the stunt helmet used by Bob Anderson for the fight scenes
Now after production they rmade a mold of a ESB helmet and from this they cast
the few ROTJ helmet's used in production for ROTJ
I will go more in details on this next post
But that is the gist of it
as well there were ESB helmets made for touring and promoting purposes but on those I don't know alot of info
perhaps someone can chime in with more details
Alright on to the ROTJ helmet info this section will be short as
it is basically the culmination of All that has happened to the ANH helmet
and made perfect in the ROTJ helmet
The ROTJ is basically in my opinion what Vader's helmet was supposed to look like from the beginning
but that is just me I love the ANH helmet and ESB helmet just as much lol
Ok so im not sure when the date for the start of ROTJ production was.
but im taking it was in the 1980's
So once production commences the crew from ILM supposedly made a mold of the ESB helmet
and then casted a handful of ROTJ helmets Hero helmets
the Fat lip stunt helmet seen in the emperors throne room was a stunt helmet made for ESB
but used in ROTJ or so most evidence would point or logic would dictate
I have my own thoughts on this and will share further on another page my own thought's and
assumption's etc
Ok so a handful of ROTJ helmets are cast they look almost identical to ESB helmets
except for
The Rotj Mask was further cleaned up made smooth
sanded sharp etc
The ROTJ Mask looks to have larger eyes than the ESB and ANH mask
yet it is not so it is merely the gloss black paint on the underside of the upper eyelid
of the eyes in contrast with the silver on top of the eyelid that gives this appearance
the eyes are same size as all other masks since they come from one mold the UK mold original
the silver inside the nose is painted after the black silver on the mask
the bottom chin vent was further enlarged from the ESB chin vent
the tusk sensors on the mask (silver metalic objects on the end of the face tubes)
where pointed at the tip and not round like the ESB and ANH sensors
Lenses are clear amber/bronzish in color with the yellow foam on the inside of the mask
giving it a sort of gold amber bonze look
the mesh is a sort of expanded metal mesh in the mouth vent's
Also the PVC dome mount is also found on top of the mask
to connect to the dome
and a piece of Velcro stuck to the forehead to connect to the dome for
extra stability
The dome is almost identical to the ESB vader dome
except for
the center strip on the dome is bit wider still over the esb center strip
the ILM crew probably added bit of putty/bondo to make it wider
Aswell the thumbprint/indentation found in the widows peak
that was left over from the ANH dome that carried over to ESB was filled in sanded smooth
and flat
it is believed the ROTJ dome already existed back in 1979 If I have it correct
so the dome would probably just have had to be molded and cast
Lastly Dome and Mask was painted in the same color and make of automotive paint
as the ESB helmet polished smooth and shiny but not showroom perfect it had paint
defects
there where various helmets used in ROTJ
and they mixed and matched domes and masks it seems
and I believe they mixed and matched Rotj domes with ESB masks and vice a versa
There are scenes in the movie one can see that ESB helmets were used
the reveal scene when Vader asks Luke to take off his mask it is an ESB helmet
But the proper reveal mask is a unique rotj mask It was painted
metallic gunmetal first and then the gloss black was added
it had no clear coat and was purely polished to shine
There is a photo where the ILM crew poses with ROTJ helmets
and it's only the helmet with the flat dome mount that is a screen used
The others with long slender PVC tubes for dome mount's were touring/promotion helmets
Now as well the ROTJ Dome sat bit higher on the face mask exposing more of the eyebrows and forehead
of the mask giving vader more of a surprised look
Now one thing im adding is that I believe and this is my opinion is they must have either removed the old ESB
dome mount from an ESB helmet and then placed a new ROTJ mount on them and then casted the mask
for If they just casted a ESB mask with the ESB dome mount ontop the Dome in rotj would have had the same spacing
as in ESB it would not have looked like the ROTJ spacing because the rotj dome mount mist be higher than the ESB to
get the ROTJ spacing of the dome or that is my own assumption perhaps someone can add to this
You can also see the reveal helmet and the ROTJ stunt had a diamond patterned shaped
mesh behind the expanded metal mesh
the reveal had this diamond patterned mesh behind both main meshes on the chin and mouth vent
the Stunt only had it on the mouth vent
Ok so that is basically it For the history of the ANH/ESB/ROTJ helmets and how they differ from all the info
I could gather on my own is it perfect no its not there is much more I don't know off
or that I forgot to mention now I will be writing up info I forgot or just interesting thoughts and
info that can hopefully add to the story
Thanks man hopefully it was all clear and understandableGreat info!!
Indeed it was all scattered in threads starting out nice then everyone fighting or it was so fragmented in threads long deadSeriously appreciate you focusing this all into 1 thread. I’ve heard the differences, but not all at once or in the same place so it’s easy to forget
Hopefully this continues to grow I will still go over all I have read and ad bits I missed out and so on lots of vader fans out there that would love to find info on Vaders helmet in one easy place
So what is the consensus on the C-scar (but don't want to open a can of worms here). I know some time ago there was an argument that it was not on the original castings and was rather a paint app. / flaw.
I have both the eFX Legend and the CFO Helmet and neither have the C-scar.
The physical artifacts that comprise the C-scar were removed from efx along with much of the surface detail of the casting. CFO, I believe, uses a 20th Century casting as the source of their Vader helmet which does not have that detail present.
CFO comes off a production made cast from the UK mold.
That's right -- the GS helmet. Thank you for reminding me! Their earlier casting is from a 20th Century helmet (the one that belonged to Darth Stone). That said, the C-scar cheek of the GS helmet was accidentally altered by its owner who attempted to strip it and in doing so damaged the casting.
Absolutely true, not arguing its provenance at all. Just pointing out, to Zenwalker's question, why the helmets do not have physical evidence of the C-scar. For reasons unique to both castings (20th C and GS) the physical traces were removed before CFO had the opportunity to make them available to us.It even has the casting worm the TM has. Proves the GS was cast during Empire production.
Awesome Gino im glad you can chime in.Just want to chime in here and say that a lot of the info stated in here is not accurate. Not saying it to start a fuss, I'm only saying this so that it isn't confused as 'fact' by a future someone searching for answers and then repeating incorrect info later. I don't have the time at the moment to go line by line and correct each incorrect item but maybe at some point when I get some free time I will.
Yes please no bog down fighting over a C-scar"But the proper reveal mask is a unique rotj mask It was painted
it had no clear coat and was purely polished to shine "
No.The masks are painted black first and the ROTJ Reveal is not polished to shine.The ROTS Reveal is only black and shiny.
Another point is that they removed the "worms" for the ROTJ masks that are casting defects from the ESB mold.
And PLEASE: No C-Scar discussion again!![]()
I'm glad we're trying to get all of this information into one location -- but we're still a work in progress and a lot of what is there is speculation -- informed speculation but speculation nonetheless. Here are some corrections I would suggest for the ANH portion of the write up (corrections noted in bold):
Production for ANH starts Mr Muir using a cast of David Prowse Shoulders and head
sculpts a face mask in clay over David Prowse plaster cast using a small side sketch of Vader's helmet provide by John Mollo.
The Mask is sculpted Asymmetrically giving Vader that perfect organic real look not that weird look of the Rots. The tusks on the side of the mask was sculpted after the Mask and then added onto the mask by Mr Muir as well as two tear ducts beneath each eye in the shape of a half moon. This is not quite correct – tusk tubes were sculpted on the sides of the face mask during the initial sculpt. What Mr Muir did, at John Barry’s request, was lengthen the tips of the tubes by about ¼” so that they extended past the bottom “lip” rather than being flush with it. “In the Shadow of Vader” pp 24-5
then he sculpt's in clay the dome on top of the face mask after this the helmet(mask and dome) is casted in plaster and is further Refined and sharpened by Mr Muir
Again, this is not quite correct. The timeline on this is that Mr Muir finished the faceplate in clay which was then given to the plasterer’s who pulled a mold and cast a plaster copy of the faceplate. Mr Muir then sculpted the dome of the helmet in clay on top of this plaster casting. Once the dome was complete it too was copied and then Mr Muir used the plaster copies to sharpen their lines and prep them for final casting. At this point the helmet was complete and fiberglass pieces were created. “In the Shadow of Vader” pp 24-5
from there it is taken by other members part of the ANH production and then further refined by them
Not sure what you mean by this. There is no evidence that I am aware of, nor have I ever seen anyone else credited for work on the sculpt of the helmet, that anyone did anything to Mr Muir’s work once he completed it. What refinements are you saying were made or is this the finishing phase of the helmet where it is trimmed, painted, and the parts installed?
Dome and Mask is then molded and casted in fiberglass ( 3 helmets are made for ANH Only one is used onscreen in the movie)
(This is incorrect, please see timeline comments above)
That's all I have for the ANH production helmet. I'll follow up with observations about ESB and RotJ as well.
Cheers,
Dave
