Since I wanted to add some more documents to the Whitefall Serenity Ships Papers I bought a while ago, I fabricated this. Blueprints based on some framedrawings I found online. I put a raster background to it, added some texture and changed the colors so it represents a blueprint. Also added some ships specs I found on the Firefly Wiki. Size is the same as Whitefalls documents, so this has to be printed on A3 and then cut out. Added a blank "back" for those who want to print it dubble sided...
View attachment 598800 View attachment 598799
Have fun. More to follow if I have time.
Not the good size for me (A3) ... The space between screws is 8.5 cm in my Ships Papers. If I print A3 it's around 10cm.Since I wanted to add some more documents to the Whitefall Serenity Ships Papers I bought a while ago, I fabricated this. Blueprints based on some framedrawings I found online. I put a raster background to it, added some texture and changed the colors so it represents a blueprint. Also added some ships specs I found on the Firefly Wiki. Size is the same as Whitefalls documents, so this has to be printed on A3 and then cut out. Added a blank "back" for those who want to print it dubble sided...
All papers are 8,5 inch x 14 inch. You just paste the image on a blank A3 and it should have the correct size. Don't resize the image to A3!
