2nd SPEAR UPDATE:
I finally got around to completing the 1st spear. It has been almost done for quite some time and actually used at Con with my predator suit. I never actually finished the end. I was just a PVC tube cut off. I need to cap off the end of the new spear so I sculpted up a end that I could use on both. I wanted this to be made from solid black resin so I could put it on the ground when holding the spear for photos and not worry about dinging it up and chipping the paint.
Here are the completed casts all cleaned up ad ready for primer.
Here are a few pics of it installed on the new spear end. The spear end has been primary colors painted and ready for some more battle damage and weathering.
DAGGERS UPDATE:
Here is a pic of both daggers and sheaths together.
The 1st dagger is all primed and ready for finish sand. I carved the center piece to look like a tooth or bone and the two side piece sort of like rams horns.
The 2nd dagger is all rough sanded and ready for a shot of primer to see exactly what it looks like.
I did some extra design work on this to make the features stand out a bit more. I brought the curved angled pieces out more and removed the centers on some so they are separated more.
The 1st dagger will have a chord wrapped handle just like my original dagger but on the 2nd I carved out a different wrap pattern in the wood and will paint if like leather.
Each time I make one of these I learn quite a bit and try to improve on the previous one..
