New one. Let me know if you see any mistakes.
I must be blind, I can't see # 152, ; )
Lol. It’s a bit out of frame isn’t it? I was using an old, old map and then went with different pics and forgot to remove it.I must be blind, I can't see # 152, ; )
Yes, I see it now! I was imagining it lying on top of the other, square piece (also from the Mustang) in a different orientation, which is why it didn't look right.Ha! that little guy took me a long time to see, also with the help of the maps.And hints from others. It is there in that kit all right, just keep looking, quite some aha moment when you find it (hint: it is cut off).
The other part #62 is also correct, just flipped on the side:
Plus you’re right on the Carro Armato I think (edit 2: now I‘m not so sure about the Carro any more)
All images curtesy of Alan Anderson.
Edit: also, nice pit you posted there!
Man how did I miss that? Epic fail. I’ll revise in a bit.You can also have a look in the parts lists, either the google doc which shows all the parts from each kit mapped so far or the spreadsheet in which the parts are listed and can be sorted by map, for instance.
And I think this cold be the hatch at the pit wall, Tamiya 1/35 Panzerkampfwagen III Ausf. M/N, A45:
That area is pretty bare now, huh? They needed better glue. Haha!Any ideas on the two circled areas? Both have fallen off and reference is hard to find. This is the top of the cockpit tube.
