YesIs that stephen210? If so, please reach out so we can sort the details!
Possible...as for asking Tom; that'll be your best betView attachment 1735708
This Looks like it!
This is a Royal Regiment of Wales belt buckle! But of course not just any buckle, from my research, this particular buckle design was only produced and made available to members of the regiment in the early 70’s. I was finally able to put my hands on two of these rare pieces!
- The Ring - Even in the zoomed blurry image we can clearly see texture there - the wreath. - match
- The Medallion - There is clearly texture there. But I think that the production probably attempted to remove the dragoon symbol by sanding or some other means.
- The Belt Loops - In proportion to the Ring and Medallion - Looks spot on!
The shape of the buckle then changed to this more standardized version:
View attachment 1735719View attachment 1735720
P.S - I looked through hundreds if not thousands of types of British buckles from different time periods, and this one is by far, the best match! Unless someone has the original, I think this is it! Maybe I’ll ask Tom Skerritt![]()
“Hi Mr Skerritt, Pleasure to meet you. I have a question, Ahmmm, Do you remember if this is the belt you wore about 45 years ago?”Possible...as for asking Tom; that'll be your best bet![]()
Well it was an assumption, and a good place to start. The film was produced in the UK, John Mollo was British, and he used what he had available which were mostly UK military bits and pieces. When I was conducting my search I didn’t only look at British belts.Why do you think it is British? This seems to look very close... The belt is even green.
Of course, all your points are valid. I actually noticed that the belt loops were square after I posted.Well it was an assumption, and a good place to start. The film was produced in the UK, John Mollo was British, and he used what he had available which were mostly UK military bits and pieces. When I was conducting my search I didn’t only look at British belts.
Correct the webbing is green just like Dallas’s. But this buckle is all wrong:
Just to name a few..
- The belt loops are square instead of rounded.
- The medallion with ring are taller then the belt loops, needs to be the other way around.
- The ring is overlapping with the belt loop, as opposed to no over lap.
If anyone comes up with a better match, Please do!
Could cast it?I feel bad thinking about sanding down the dragoon....
Here is my interpretation of the crew jacket to add to the many here.
Last year, I spotted a Japanese-made MK3 RAF Cold Weather Jacket in black from Waiper on Japanese shopping site Rakuten for about £200. Expensive yes, but as black is my colour of choice (and I'm never going to find an original RAF blue/grey/purple version), I couldn't pass it up. UK customs stung me for fees and VAT though.
cheers all
Steve
Could be a flipped negative too...I keep searching and searching....and.....
Is it possible that Dallas was a little clueless?
