Thinking of doing led’s in the cockpit. The dash is removable so wiring and battery placement would be simple. If I do that I will probably go ahead and put plexiglass on the canopy which might lead to a minor design change with it. Maybe. But if I leave off the plexi I could reach in the cockpit and turn it on that way, I just thought that up.
I had a wild idea of using a leftover colored nitrous purge system and install in each engine, run the lines down thru the stand and out to a bottle, with a flip purge a blue exhaust fog out the engines. It would look cool but that was if it stayed outside. If you’ve ever seen the colored purge systems work they can blow a 15 ft spray and look bad ass.
