The Expanse: Props & Found Parts
Fantastic work! Those really turned out nicely. You did an amazing job with them.
Gotta admit. I'm a little jealous. ;)
Terry
Re: The Expanse: Prop Weapons
OK, the new tac-light is the LaserTac subcompact combo green laser & flashlight. Retail is $130 US.
-MJ
For the Martian Pistol Tac light, here is a knock off on sale with a 15% off coupon for $33 on Amazon
After binge watching all 6 seasons for the first time I knew there was one ubiquitous prop I really wanted to make.
I just finished my Belter Hand Terminal.
It has the same "slap band" led circuit inside with the on and flash mode. I had to de-solder the blue LED and replace it with a yellow SMT one which was a really fiddly job but I got there in the end.
I may print out a graphic for the display but for I'm happy that this is a set accurate prop.
Would you be up for sharing the template?
Look like orange bracelets available
EDIT: Nevermind, found em on Thingverse
I am currently re-watching the show, and got in the mood to try my hands at a paper prop. It's the code word sheet Alex pulls from the Roci's operations locker.
Here's what I have cobbled together so far. I am still fiddling around with the spacing of the respective text blocks.
As far as the fonts go, I used one called "Federation" for the actual code words, and I think it is a near enough match.
However, I am pretty certain that the "COMMAND STAFF ONLY" line has the wrong font. The one I used is "Flexi-IBM-VGA-False", and it is quite close - except for the "D".
Can anyone identify the font they actually used?
I am currently re-watching the show, and got in the mood to try my hands at a paper prop. It's the code word sheet Alex pulls from the Roci's operations locker.View attachment 1613795
Here's the one I did a couple of years ago, I don't know if the font is correct, but it looks closer than yours. I can check back on my files, but I just arrived for two week's holiday in Portugal, and the files are on an external drive at home. Can check when I get back if helpful? I do recall the other font I used is Aldrich, as I used it on many Expanse props.
Thank you for the Aldrich font tip!
There is no hurry, though. I am still pondering whether at all I will turn this into a physical prop, and how.
I have looked at the COMMAND STAFF font for a while now, and I don't think your and mine hit it on the nail. It seems that, if one would mix our both choices, that would be pretty much spot on.
The "A" has a distinct shape that is close to my version, but overall, the letters are straightforward, without all the serifing about of mine. Like in the font you used.
Which means more font hunt! :)
Update:
I may have come across the correct font for CO MAND STAFF ONL. It seems to be "ProFontWimdows", and it appears to be a match.
Following Murphy's Law, of course, the only letter that is very hard to identify in the screen capture is the "Y", but from what I can glean from other screengrabs, this seems to be it.
So, for the moment, this is how my code word sheet looks like, after adjusting the spacing as well:
(sighs)
So, obviously, it couldn't have been that easy. I have found another font, "ModeNine", that seems to be more accurate. It seems to have the right "M", "S" and "N".
This is how it looks in context:
Really nice work. It looks great guys. Bear in mind that some times the graphics dept on show like this will take an existing font, set the type, then convert it to outlines and modify the font here and there. They also create their own fonts. So you may not find an exact match.
Ah, thanks, Noeland, I probably needed that. I was half-way back to those font websites again... :)
Thats what I wanted to know.
Keep an eye on the junkyard, or prepare to try for an original in the up-coming propstore auction?
I know I dont stand a chance, but I can dream.
Hey all, apologies for the Thread Necromancy, but I wanted to add some bits to it for posterity and for folks like myself that still run across it and can use the information here.
First, I want to add a link to the Propstore final Expanse auction for it's detail photos and some good info: https://propstoreauction.com/auctions/info/id/412
Second, I won Lot # 224: The Expanse (2015-2022): Amos Burton's (Wes Chatham) Season 5 Jumpsuit with Earth Costume Components https://propstoreauction.com/lot-de...der=order_num&xclosed=no&featured=no&key=amos
If anyone has any questions I can answer about that lot, just ping me. I didn't see a label inside the coveralls which appear to be a cotton canvas, so I suspect that these were hand-made by the costume dept. Amos's grey Rocinante jacket from that same lot is tagged, and it's an Acrteryx Gamma MX Hoody Men's, size Large.
I also bought an MCRN small ammo can for "12mm Caseless" ammo from an eBay prop seller, detailed photos attached. It appears to be an older black Plano Field Box. Amazon has the current model here Amazon.com although the latching is a little different. If you want the exact latch (with brass clip) is still sold as part of other Plano field boxes on Amazon and I can confirm that you can swap the parts. On the prop, the brass latch was removed and the lid has been super-glued in place.
Good to be here. I've never been a hardcore prop replicator before, but I've made my own sci-fi props here and there over the last 40 years, and I definitely put myself in the "Maker" category. Now I'm busy replicating the MCRN pistol (twice over) and other Expanse props as I still love the show. Thanks to all who posted great info here, some of it almost a decade ago now.
