Nokitten
Jr Member
This is based on skynet model, but absolutely everything is changed or remadewhich scale are these? did you alter one of the avaiable models (Djon / skynet / DeltaDesignRus)?
I guess so,it looks not bad,but I just can’t ignore itCould be a design choice so they can always identify their sculpt if others try to pass it off as their own.
They often add in oddities... so this could be one of them.
Or could just be a mistake.
First I combined all the parts of the skull into one solid mesh, and then made changes. Sometimes I paused, looking at the photo in more detail. Sometimes it seemed that I had finished, but after a while I continued again. And now again it seems to me that it looks cool, but for how longI'm in the process of modifying his V2 model, I think the huge cavity under the skull bonnet and the overall design of the parts fitting together is far away from practical.
I'm in the process of doing the same and I absolutely fell in love with meshmixer. I cut out the two cavities (chip / under the bonnet), inserted chip cover and bonnet, connected the front skull part, made the whole thing hollow and then remeshed in in blender.First I combined all the parts of the skull into one solid mesh, and then made changes. Sometimes I paused, looking at the photo in more detail. Sometimes it seemed that I had finished, but after a while I continued again. And now again it seems to me that it looks cool, but for how long![]()
how much did you have to scale it up? I wonder how accurate the skynet2029 skull is regarding size.This is roughly how the Foam Skull could have looked if they had placed the top part perfectly on the jaw, instead of how they did it, hiding the lower teeth. Using the M1 scan jaw as an example. It hasn't been properly sized for the Foam Skull jaw, but it works for the visual. Also added in the M1 temple insert just for fun. It had to be scaled up quite a bit to fit.
I am sorry if this was already covered (used the search function but found nothing specific)...
I've read that Radio Shack 12v signal lamp covers are used in various builds...but I couldn't find an exact part number or any info on a good substitute for the Radio Shack cover.
Also, is there any info on the fittings of the hydraulic / water steel flex hoses which connect to the skull?
