Spaceballs Dark Helmet
Springboarding off of a Halo costume I was thinking about a great halloween costume character to create and wear at parties. Weighing the pros and cons of a bunch of costumes (including buzz lightyear and the predator) I decided to settle on an old favorite movie of mine from childhood; Spaceballs. With the help of a newly acquired 3D Printer, and the knowledge gained from creating the Halo Armor, I decided to create a Dark Helmet Costume.
Step 1 - Obtain a pepakura file of the Helmet. For that, I used Dark Helmet helmet by Darkside501st. I have to give the creators of the pdo files a lot of credit for their time and effort contributed. Thank you. After resizing and printing the helmet on 100lb stock paper, it was time to start cutting and gluing. Nothing new here, just applying what I did with Halo armor below:
Used cardboard to reinforce supports. This decreases warping when applying fiberglass resin.
Step 2 - Coat with Fiberglass Resin:
Step 3 - Apply the Bondo:
Step 4 - I decided to pull part of the mask out of the PDO and use the program Blender to help turn it into a 3d print .stl file. The below was the result:
Daughter photobomb! Since the mask was too big for the printer, I split it into 3 parts. You can see the seams above. Each seam was sanded and painted smooth. When gluing the parts together, I used hot glue first, then a rondo layer over the seam and fiber tape across the seam as well. The fibers add a lot of strength.
Dry fit the pieces together. Looking good so far.
Step 5 - Now for the hard part. I need this thing to sit on my head and not my shoulders. I don't have many pictures but I should be able to give you an idea of how it was done.
I took a a hard hat that has an internal head holder like the one below:
Then cut the top of the hard hat off.
I cut along the top so that the dark helmet faceplate has a place to go when it is in the up position.
With the hard hat ready, I mounted it to the helmet making sure to place screws on the back half only.
Step 6 - Dryfit the helmet.
You can see the hinges above on either side.
Step 7 - Create tinted visors using plexiglass and car tint.
Step 8 - Paint and Finish assembly
The Clothes were a bit harder. Looking at a reference picture, I needed to figure out each piece of the costume. The easiest parts to acquire were the glovesand boots. The rest had to be sewn from scratch using 5 yards of black pleather, some backer rod, and pyramid studs for the arms, gauntlets and around the coller.
The Shorts:
To sew the shorts, I used this video on youtube to help establish a pattern. The rest came together rather easy. Thanks C Martinez.
The Belt Buckle:
This was rather involved and I needed to know how to use blender. After some time creating, I finished with the following designs:
Pyramid studs:
I couldn't find any online the right size (3/4" x 3/4") so I made some on the 3d printer and placed a hole in the bottom to screw in an 8-32 1/4" screw. Worked nicely.
The Chest:
Basically difficult to describe but I used an old shirt as a template on the pleather and stitched along the seams. I placed a seam going up the middle of the chest and used the tie to cover all seams. The tie is sewn to one side and attached to the other with velcro.
The shoulder pads are attached via velcro and made from the same mats used in a gym (eva foam). It was a very basic design and I used heat gun to give it a curve.
Using an old underarmour shirt and wrapping the backer rod with pleather, the costume winds down to a close.
The final touch I added was a sound speaker hidden under the cape that plays "The Spinners - Spaceballs" theme song from my phone clipped to my shorts. The only problem is I might be too tall to play the part, that that's not going to stop me.
Thanks for looking.
Until next time, KEEP FIRING A**HOLES!
At the request of some RPF members, I'm sharing the STL files I used to make my costume. Some modifications may need to be made. If you used any of my files, please do me a favor and send pictures of it all done. I'd love to see it. Enjoy!
How did you install your hard hat for your dark helmet cause im stuck at doing that part cause im trying to cosplay as dark helmet next year
This has changed a bit with the new setup but the idea is still the same.
Step 1, cut the construction helmet along the black line:
Step 2: attach the back of the construction helmet to the back of the Dark helmet using any means you like. My first one was casting a nut inside of rondo and using a screw with a fender washer from the back of the construction helmet into the nut.
Below are pictures of the original:
Step 3: Attach a hinge for the front mask to get attached to. The hinges on the side of the helmet are just T-nuts glued to the inside. The metal brackets are Simpson Strong Tie Tension Bridge cut up and drilled as I needed them. These simpson straps run to the face plate through the 2 slots on either side and secured with a screw.
Step 4, attach a string from the hinge (close to the helmet) to the construction helmet on both sides. This will prevent the helmet from fully swinging forward and down.
Can this proceedure be perfected? Sure, but this was my proceedure even on my second helmet with the 3D printing.
Thank you for the pictures so I can do my dark helmet cosplay
Hey Moe, quick question. Where did you get the glasses for your costume? I didn't see that mentioned in the thread.
That's just plexiglass you buy at the big box home improvement store. There is a picture of it on page 1:
It is basically plastic so you can cut it with tools like a band saw. Just take it slow as this likes to chip when cutting. I usually go a little big and run it under a belt sander to get perfect.
Sorry let me clarify. I am talking about the round black eye glasses that your wearing under the helmet! HA I have the plexiglass already figured out.
I am trying to find accurate ones and while I have found some that are close to the design from the movie. The ones I have found are not quite right.
Too funny. I'm pretty sure those are harry potter novelty glasses I stole from my son's previous costume. You can find a pair here.
Hello MoeSizzlac ! Sorry for messaging you on multiple platforms, but I'm desperate! I have been using your amazing Dark Helmet build as a basis for making my own halloween costume. I wasn't sure what kind of hinges you used to make the mask go into the helmet and where to obtain them? If you could give me any info it would be greatly appreciated!
Thanks for any help you can give!
Hello! Sorry for messaging you on multiple platforms, but I'm desperate! I have been using your amazing Dark Helmet build as a basis for making my own halloween costume. I wasn't sure what kind of hinges you used to make the mask go into the helmet and where to obtain them? If you could give me any info it would be greatly appreciated!
You can call MoeSizzlac to this thread. Otherwise he might not get a notification
The Hinges I used were custom made. These were the parts I used:
1) 8/32 t-nut (m4 if using metric)
2) 8/32 screws (cut to length)
3) 8/32 Nuts with nylon
4) Nylon String
5) Simpson Tension Bridging tie (Hammered Flat)
6) Foam Pad
7) Red Thread locker
The Foam at the top is to provide friction for the helmet to stay up when pushed in the up position.
The red thread locker is so the screw does not come out of the T-nut glued to the helmet. Use an epoxy to glue the T-nut.
The String prevents the helmet from falling down too far.
The tension bridge on the inside of the face mask prevents the helmet from tipping forward too much
Since the hard hat is cut, this allows the face mast to glide up above your head. The majority of the weight is being held by the back of the helmet where it attaches to the hard hat band.
I'm sure you'll have more questions so let me know and I'll try my best to help you out.
Hey Moe! I just finished building one for myself and wanted to thank you for the files and detailed tutorial. I had to cut a few details to make the Halloween deadline, but I'm still super happy with how it turned out!
My turn to say thank you MoeSizzlac ! I have had my eye on a Dark Helmet project for a while now and finally was able to focus on completing.
In the spirit of sharing, I am willing to post details if requested, but in summary I printed the (second) helmet in ABS and utilized most of your parts but in a different way. I didn't feel my hard hat was rigid enough to hold the weight of the helmet so I ended up using shapes and the Mesh Boolean settings (from the 3d Orca slicer) to fill in the void between the helmet sides and back to meet the hard hat as braces. I also did the same for the pivot points for the facemask as shown in the first photo (early prototype):
To keep the helmet up, I used strong magnets (you can see the circle recesses in the first image to the left and right of the hard hat). I used the t-nut method to attach sides and back of the hard hat and for the pivot points.
Second photo shows it in the helmet (again early prototype but easier to see with the different colors as the interior was painted black once complete):
I positioned the braces on the left and right side of the hard hat such to act as a stopping point when the face mask was lifted and where magnets would hold the mask open.
Edit: I used picture hanging hardware anchored to the hard hat and to the facemask when in the down position
I created and 3d printed the collar armor and circle (we called them cinnamon rolls) chest pieces. I printed the ring in transparent PETG and added a simple green led with a button to turn the ring green when pressed to activate the schwartz. I had help with the cape, shorts, tie and shoulder harness. I got the hard hat, and gloves from Amazon, the belt and boots (very hard to find something similar to the movie) from Temu. Most of the items are held in position by velcro.
We attended the Halifax, Nova Scotia Hal-Con this past weekend and made a lot of friends:
...all while looking for Lone Starr...almost got him and the Princess with some help from other Spaceballs:
...she's not in here!
I have a lot more photos but overall, the Dark Helmet costume was better received than I imagined and brought many smiles and happiness to those that came up to me with photo requests and appreciation for the work which should be shared with you. Thank you Moe!
PS. I just created an account to post this so hopefully this goes through (fingers crossed) and you see it Moe!
