Too Much Garlic
Master Member
You can only fill the same area the same way roughly once, especially if you are doing a rush job, just to conceal the undercuts present at the tubes. That roughness of the filler will be on ALL the casts from that mold and you'd have to clean up the cast extensively to remove that detail and seeing as filler detail matches, I'd say they didn't remove that detail that links these together.
The UK mold helmets have similar filler details in common that are unique to that family of helmets and the fact that those details are there on those casts connects them to a single molding off that original, but at different stages in lineage, if you understand my meaning.
The Rick Baker mold is a second molding of the original helmet at a later time and the filler details are consistent between the casts from that mold. They do not match the UK style helmets, which is a good way to set them apart. And because of that filler the Rick Baker casts will never be as accurate to the screen used ANH as an untampered with straight out of the UK mold cast will be.
It is not a cast from the ANH production mold that created the screen used helmet. It is confirmed to be molded and cast off the screen used ANH and connected to the Rick Baker mold.
Hope that makes sense.
