most people/pretty much every "build up a helmet" instruction I've found, points to using this thing.Finally beginning my Mando build. Anyone have a good source on the correct colored visor?
I'm aware of dented helmet. That visor doesn't appear to be tinted the way Mando's is. His visor has a blue-ish purple color to it.most people/pretty much every "build up a helmet" instruction I've found, points to using this thing.
I think the only exception you're going to find, is when a builder sells unfinished helmets, and make his own visor inserts that come with it. If you're really worried, you can go scope out The Dented Helmet; it's the RFP sister site that's all about mando costumes. There's a link to it under the star wars costumes section.
Hero helmet, meaning one of the main ones used for the show. Screen used.Those still look REALLY good, also Mr.MoldMaker when you say you’ve seen through the hero props visor are you referencing the Anovos helmet or the actual screen used helmet?
The double visor?Glad it was of some help benhs.
Anovos is a replica. Their visor set up is weird and incorrect.
Everything. The double visor, the purple color, the attachment. It’s all weird and incorrect. I have no idea why they did it that way.The double visor?
I swear there are shots where it apprears purple.Everything. The double visor, the purple color, the attachment. It’s all weird and incorrect. I have no idea why they did it that way.
I promise you it isn’t. If anything it is just lighting. Looking through, it’s a blue tint.I swear there are shots where it apprears purple.
The double visor is so dumb on the Anovos. I replaced it with a welding lens. The welding lens the exact same thickness as the original visor, yet it's much darker and less brittle. If they had just use a darker visor, there'd be no need for the secondary one.Everything. The double visor, the purple color, the attachment. It’s all weird and incorrect. I have no idea why they did it that way.
