GONK!
Back to work...
Today some minor progress on the feet:
This isn't glued yet, it's just for imagine how will it look:
And glueing together:
Today I made the nib cutouts. Everything is glued together except the top sections.
I also started on the legs. No pics yet ;)
I'm still thinking with what can I fill the feet (maybe stones/sand?) or if I leave them hollow. I will probably test it hollow vs filled and see what works better.
Ideally, I think some heavy ball bearings would work, but that could get very expensive.
Yes, that would be probably very expensive. And we have some stones in our old cellar, so I think I can use them.
After a line of some minor updates, here comes a super big update! :)
A lot of photos aswell ;)
Cut out some decorational panels from styrene and glued them on, including the E:
I was inspired mainly by the new Battlefront (front down panel) and by TCW Gonk (three back pieces).
Side details of the feet:
Completed legs:
Not screwed together yet:
And I just wanted to see, how does it look:
Tomorrow trimming and bondoing when the weather is good.
What do you all think? Any criticism welcomed :)
Looks good! I am still not sure what to cut for my details but seeing how well the styrene turned out for you I may use that.
Thanks! I use styrene for most of the details on my builds, because it's easy to work with it. The hardest part on this were the holes on the feet deatils. I usually cut pieces with exacto knife, but for them was dremel better ;)
I had no time today for bondoing, but on the other hand I trimmed and sanded the Gonk thorough.
Drilled holes on the back of the feet for hoses:
Glued and drilled the feet together. They're filled with stones, so they are pretty heavy :)
And once again putted together. From these pictures the feet seem to be too big, but maybe it is just me. What do you think?
Bondo is next on the list! ;)
Even though the weather isn't ideal today, I spent about 2 hours with bondoing the parts. I'm just waiting until the bondo is hard and I can sand it.
Feet is looking right scale to me.
How did you do the trim piece where the bottom and top halves meet?
-Eric
-Eric
I cut long pieces of wood, which fitted around the body (about 4 cm high) and screwed them to the bottom part, but with half of it overlapping the top (so 2 cm are screwed to the bottom and 2 cm jut out). In the pictures you can see styrene plates on it. They're simply glued on. Then I trimmed the corners, so they are nosing. I bondoed it and now I am going to sand it.
