Fullsize Alien Warrior Build (Xenomorph)
Wow...repetitive work right there Metalalieno_Oo_O I certainly admire your dedication:cool::cool:(y)(y)
cut glue cut glue cut glue cut glue cut glue cut glue cut glue cut glue cut glue cut glue cut glue cut glue
Not sure you can tell from the pic but all those little pieces of foam I keep adding are basically the skeleton for the clay foam. It helps it keep it shape cause clay foam likes to sag and deflate while drying. If I did the whole tail out of Apoxie clay it would be WAY too heavy.
- In theory, would another option be glued sections of styrofoam (with metal armature), sculpted and then finished with an epoxy clay?
yea you can do an outer layer of apoxie clay on top of lighter filler. That is how I did the hands. If the tail doesn't look right after the clay foam I still might have to do that.
Trying to avoid apoxie clay on something this big.. The ribs are almost all apoxie clay the torso got heavy real fast. I still have to hang this from the ceiling.
Gonna have to do apoxie clay over the clay foam... the clay foam just isn't giving me the detail I want... sucks cause all this just adds weight and time..
-That is too bad. Hope the Apoxie will be thick/strong enough to not crack over time as the foam flexes. There isn't a flexible epoxy clay is there?
Wonderful workmanship:cool::cool:(y)(y)Are you going to weigh the tail? Would be interesting to know;)
I could do that when it's done.. I have been trying a different technique where I am putting only a thin layer of clay foam.. that wasn't my origianl plan I wanted to have more to sculpt with but I wanted to see what it would look like... seems better than the saggy mess of putting it on thicker.
I just feel bad for guys who had to make this in miniature like the guys who work for Hot Toys or Sideshow. Some of the Alien figures have more than one Alien so thay had to make this thing more than once back to back!
