Hi All,
So many broken links
Will need to fix that up.
If anyone can recall this costume was meant to be finished by late october 2012 for my mates party. Unfortunately the suit ended up being waaay too small for me, meaning I had to put the build on the backburner for a while. This was due to the duct tape dummy not being sufficiently stuffed and initially being wrapped on too tight.
Since then I have decided to give it another crack for an upcoming costume party.
First and foremost I needed to make another duct tape dummy. This time we applied the duct tape in strips and ensured it was stuffed to bursting point.
Measuring it up it still need more "girth" (didnt want to take any chances). I added layers of insulation and foam to beef it up, may be big but at least it will fit me.
Next I thought I would have a crack at the neck rings. I used foil and duct tape to shape my neck, then attached it to the dummy to give a base to work on. Next I threaded coat hanger wire through a vacuum hose to shape the first ring around my shoulders, then gradually superglued each ring to the desired height.
I also started to cast the trophies (there's a few more I need to do). These were basically glove moulded around a clay mould with silicon, then cast with Polyurethane resin.
I bought a mexican wrestler costume HOPING it had some decent muscle shape, but as usual I got stooged and would have been better off with a set of pyjamas. Nevertheless I slipped it on and gave it a layer of latex.
This time the muscle shaping was a breeze, same method as last time, stocking, stuffing and string.
This is after 3 layers of latex, IMO it is looking MUCH better than the last one.
Next step is the back, then adding some detail
