DL-44 ESB Blaster Discussion - Greeblies POST 208
What about theese screw on caps a possible candidate for the mystery knob, that fell off the DL 44 on Finse?
1. The SP220 scope was made in the UK.
2. The scope was used on the DH 17, making the caps an available item for the prop builders
3. The depth seems to accomedate the height of the screws.
Not sure of the width, ive asked a guy who's currently selling one such scope.
If its 27mm +- it would certainly fit.
These Caps are way too small - these are more in the 10-15mm mark.
Yeah but you can tell it is not true. Just looking at it compared to the size of the piston halves I think the diameter is no bigger than the piston half length that makes it 18mm. Besides it only barely covers half of the screws it is certainly not as large as the disc.
So some sort of windage / turret cap perhaps and leave the rest up to imagination :p
Something in the line of this then?
I absolutely hate it too lol
The fact that it covered part of the screw heads kinda always weirds me out.
We know from its appearance on the Today show that the cut-out for the nuts on the sides of the pistons is large and sloppy, with lots of extra space. It also seems like the gray epoxy in the center is in the shape of a hexagon, makes me think it’s some sort of knob or something with a stem?
Perhaps? The mystery-knob would had have to be glued to the disc, if it did not cover the enter disk.
And that would not have worked if the knob was hollow i guess.
Either covering parts, or the entire disc - it's an annoying knob :p
One thing tho - that bugs me:
Could the glue / goop in the center of the non- Thorens disc cause it to appear flat?
And the mystery disc could as well been a tonearm bearing dust cap?
Just my two cents..
Why cant the "non" Thorens disc actually be a Thorens disc. The indentation in the center could be covered with glue, and that causes it to appear flat.
Just my two cents..
The Thorens disk is very thin - the actual blaster has a much thicker disc.
Why not - they had alot ff parts from model kits available. Not to mention the V8 kit.
Call it best candidate for now?
totally. I think Chris is right about this. I made a few molds to test out this theory and I think it IS trimmed a little.
I want to discuss theese if possible?
I've done some reading in this thread, and ive seen some various solutions on how people here have approached its looks.
They are as i understand, resin casts
Ive studied the photos at various angles, zoom levels and colours
Both holes to me appear solid, with resin - The left one has something that appears to be a screw, but the hole sits too low for me to be a screw. Looks more like some minor hole or irrgular casting error?
And the right side coil part has a solid hole.
Theese were not screwed on, but glued since there appears no holes on the left side when we saw the blaster in the hands of Al Roker. As they had fallen off at some point
But thats just my eyes, what is the consensus at this forum?
Back in the day we thought they were screws. It’s super easy to smear clay in the holes of a motor coil plate and cast it with a half an ounce of silicone. Or to take an original and fill the center with glue or putty. I think either of these is the most probable option, seeing as they were glued on
Thanks for the clarification :) I guess back then they did not care much about clearing the finished piece.
I did this, inserted some plastic wheel hubs, filed and painted.
