DeAgostini 32" Falcon (Rescue Project)
Dude - I LOVE that Highlighter pen thing! It may not be 100000% accurate but who cares its cool as all get out!
Jedi Dade
Thanks JD.....It's just an attempt to make something with a bit of beef,....Hopefully it will look OK with lights, & will still look good when they are off
So this is how it looks now..
Thanks for looking
J
So cool !!! Really like the slight , discernible ridged details on the interior’s of each of the cutout/housing’s in pic #2 - byproduct of the markers ?
Please , could you share what type of lighting setup you’re using to achieve that beautifully diffused intensity , also , was the curvature of the pieces difficult to assemble/maintain in that area ? :eek:(y)
Ged
Hi Ged, yes those ridges were there to keep the felt tip marker inside the pen holder.....I just yanked the part out of the holder with pliers, i t gives it a bit of machine detail
Because the shape of the pen tapered down, when lined up next to each other they formed a natural curve
The lights are 2 COB inserts from an Eveready inspection lamp (image below shows Rolson, but exact same product badged), the power will be 5v from a USB phone charger
The diffused filter was from a ring binder folder picked up from a stationary shop
Thanks Ged for the interest
John
I've done a bit more to the engines,....using PVC Foamex to create a centre band, then adding strips of Evergreen Styrene,....the upright vanes made from styrene card were mounted on Panther tank track pieces:
I then added more vertical vanes:
Thanks for looking
John
Hi guys I've started painting,....decided to go with Archive X Reefer White instead of the Grime LT that I had intended doing....although totally accurate to the 32" filming model, to me it looked a bit too dark,...so Reefer White looks better for me
Various stages, top images most recent
Thanks for looking
John
Really looks good. Could you let me know how many bottles of the Archive X Reefer White you use to cover the whole thing? I want to order their paint when it comes time to paint mine and would like to know how much to get.
Thanks very much mstorin,....I used a jar for the top,....I haven't painted the bottom yet.....so I'd say 3 jars will definitely do the job
J
Beautiful weathering mate, absolutely stunning work when seen (zoomed in) close up pics on my tablet - the detail especially on those actuator panels/flaps on the upper hull ...:love: !
Please forgive my ignorance, if it’s already been asked and explained, but why did you replace (?) the circular vents on the escape/docking pod corridors ?
Just curious.
Cheers, Ged
Just curious.
Cheers, Ged
Wow, thanks for the comments Ged
Yes...thats my goal,....to try & make a 32" paint job,...everything as it should be at a glance,...including signatures, but on closer inspection there's a lot more going on,..more detail, hopefully a more precise job,...we all know the pressures that were on the ILM guys when they painted the 32",...& because the model wasn't intended to be studied, you can see all the overspray & loosely masked areas....splatter, hand drawn decals etc..
Adding PE grilles is a step away from the studio model, but it adds more functionality like the 5 footer, more to look at
Theres PE on the set from Nico Möbius for the vents on the docking corridors.....here's one just set in,...no paint yet
Thanks Ged,...yours is looking cracker by the way
John
Cheers for the detailed reply John, much appreciated.
Thanks also for your kind comments re; my build.
I finally understand the situation regarding the smaller vents...,WOW ! :eek:, had no idea that’s how they went together on the 5ft version ? Brilliant.
Seriously Awesome Detailing & Details..., The bar you’ve set, is pretty much in orbit now mate!
(y) Ged
I did some refinements to the finer pipework.....noticed some were the wrong angle (& one still needs fixed)
A lot happier,....apart from one
& some more shots of the engine deck, some parts aren't glued down yet, thats why the actuators move about:
Thanks for looking
John
