Done / Completed CW The Flash TV Show - CC Jitters Mugs!
Here is the prototype! What does everyone think?
I think the colors look pretty close to the show.
You can see the center part really pops, against shadow.
A few things I noticed:
The green mug is slightly shorter than the brown mug.
Slightly bigger gap between the smoke and the mug graphic.
Slightly bigger gap between the 2 letter C
Everything you pointed out I see. Had you not pointed them out, I would have had no clue lol
It's not that noticeable, unless you have the 2 side by side.
I know printing can create this slight variations, from time to time. There are worse errors in the show :lol:
This one was likely due to the print position being slightly lower on the mug.
The mug curves more, towards the base. So the lower the graphic is, the more distorted it will get.
I will try to adjust it higher.
Bump for more interest.
Killer Frost and Try the Flash drink poster displays are also in the works:
if the brown mugs are going to be on hold for a bit from JKRIB, i do have a couple of brown mugs currently for sale in the Junkyard forum. feel free to take a look. thanks.
