Coming up with a bat suit of my own
Looking good! I'd have to see how the cape comes together at the single point - my initial thought is that would make it tight around your neck, but maybe I'm not visualizing it correctly?
You just might be right. Painted over the armor parts but since it’s mate, it leaves traces under the sun ( I don’t plan to be daytime Batman but still)… anyone knows how to fix that? Diluted acetone?
Well apparently:
Use a fine grit (a 220 grit sanding sponge works great) and just go over everything quickly. You don't want to sand the paint off, you just want to smooth it out a bit before applying another coat
So I’ve done a lot of dremel work on the jaw part, three tiny magnets on each side, one outside I’ll paint over. A bit of sagging….black elastic inside I guess should fix it.
Just got magnets… symbol in place.
Well here’s part of what I’ve gathered, minus the belt and gauntlets. It’s I feel a satisfying first draft. The logistics of putting all this together, making it wearable ( the bike armour armour underneath has a zipper), is intense. I’ll have to use Velcro and or magnets to connect the armour pieces going over it. The shoulder pads will need help to stay in place. Biceps will be arriving shortly.
Looking good! The yellow accents on the shoulder armor have me wondering about a yellow outline for the bat insignia on the chest emblem - as a way to pull it all together. Just a thought.
For consideration - here is a quick mock-up...
That looks cool! Love your input. Actually the yellow might be swapped for brass, with a few touches of brass here and there. For the emblem, I still want to try putting a very dim light behind it, with a remote control. I showed a quick attempt a while ago see below
Imagine you’re walking at night, barely any light. Than this shows up in front of you
Gonna have to change the light I chose, too bulky on the chest. Should be getting fairy lights with a remote control tomorrow
