Accurate B-01 Tactical Armour (Helldivers 2)
AstroChrisX
New Member
Hi guys! This is my first post so apologies for any faux pas!
I've been infatuated by the B-01 armour from Helldivers 2 ever since the launch trailer came out! It looks so awesome, so I've decided to start making my own set! There's been a few stumbling blocks here and there which I'll go into in a bit. If you're not aware of what the B-01 armour looks like, it's the default armour in the game and has a snazzy black and yellow paint scheme
It looks awesome (Although perhaps in the future I may do some other armours from the game too?? hmmmmmm)! The folks over at Galactic Armoury made some great 3D printable files so I hopped on and started printing! I printed everything out of PETG, 3 walls on everything because I just wanted everything to be nice and solid and just to prevent any warping that may or may not occur.
The goal of this was to create a really great costume, as accurate as I could possibly make it (This comes into play later)
This is also my first real foray into large scale printing of a costume or armour so there were definitely some teething issues. Fortunately I do have a pretty good printer, an Elegoo Neptune 3 Plus. So I don't need to split parts up to print pieces which is pretty convenient.
My first stop was to print the helmet first, the file is split into 3 parts or fully assembled; a face plate, helmet dome and helmet rear/bottom. This is where my first issue arose, I should have definitely printed it all as one piece, my printer could accommodate it so why not! Well I figured that it'd be easier to sand and finish all the parts first then assemble them together and the orientation of the parts I thought could be printed better split up. I'm not doing that again! I ended up with lots of support along the helmet dome and bottom interface which gave a few unsightly marks, I was still during this time trying to dial in my settings so there was also some lifting on the buildplate which caused a feature to be warped a little. However all in all it came out pretty well and the print quality (support surface notwithstanding) was pretty good! I'm still in the process of finishing the helmet but I first applied a layer of UV resin to smooth out a lot of the layer lines, then sanded, then applied some filler putty and sanded down, sanded down again and primed. I got a few imperfections I've filled again and it's currently waiting to sand it down to it's final state. I'm hoping the gloss paint scheme will hide the crimes so to speak!
Now onto the actual armour, I first started with the smaller pieces like the forearms, tacpad, shin armour etc. Tweaking my print settings before finally getting around to printing the torso parts. All in all there's 11 pieces to the torso armour with 2 very large parts that only just fit on my printer! Assembled together using CA glue and activator. I actually believe this combination is magic! I've never used it before but being able to instantly fix two parts together rock solidly is the best feeling ever! So far these parts were given a quick sand and then a layer of UV resin again. You can still see layer lines through the resin but you don't feel them, and the resin sands very nicely (With an appropriate full face respirator mind you). This is a nice technique I'll be continuing to use.
This is where the story switches gear a little...
So far I had printed almost everything, everything except the thigh armour. Enough that I wanted to start thinking about the soft parts, now because I wanted an accurate set of costume I wanted to have accurate soft parts. I believe this is where some other examples have been let down, I want to create something that you look at and think "yup, that's how it'd be done in real life". With that in mind I'm looking at creating a custom plate carrier/ballistic vest for this armour using cordura and spacer foam like you'd expect on a real bit of military equipment. I've seen other examples of this costume using duck cloth for parts or using a waffle pattern fabric, however looking at the reference pictures it looks like the majority of the soft parts were in cordura which makes sense, it's used to make backpacks and plate carriers today so they're likely to be using something similar in the future! This should give it an accurate texture that replicates the texture on the game model. I've started work on the template for the vest and it's coming along pretty well. There's lots of bits and pieces to the vest, this is just the front panel! It's made up of 7 'sub-panels' and each one has varying levels of padding inside.
This is a complicated vest to create so my mind started wandering and looking at the other parts of the soft parts of the armour, all seemed well until...
EVERYTHING FALLS APART
I was happy... I was content... then I had to go and have a look at some of the references I had collected. My biggest reference is a 3d model of the armour ripped from the game, I found it on the Helldivers 2 Archive channel on discord. It's a fantastic reference, fully textured and you can rotate it to any angle you want.
So looking at the reference 3d model I see that the shoulder pauldrons had a big soft pad under them which I was looking to replicate. But actually looking at the 3D prints I've done for the shoulders there's a large chunk of plastic where that pad should be... looking at the reference and print it's obvious to me now that it's not quite right. I should have really known since there's a buckle right there which wouldn't make sense to be on TOP of the hard armour, as soon as you crank down on it it'd start flexing the armour not cinch down on your arm!
You can see the difference between the 3d printed part and the reference. I've drawn on it where I need to remove material. I was looking at the part even closer now, I started noticing that some details are missing, or wrong (For example there's a bolt inside the feature on the front which is missing in the print, that feature looks very "sharp" on the print compared to the model, some parts are smooth where there should be an edge like the top of the pauldron and bevels are missing). Hmmm okay well maybe I can just trim this bit of plastic away and try to adjust the other issues but I should check the other parts just to be sure.
This was my downfall, to my surprise most of the parts are just wrong, the most egregious is the fact most of the soft parts are actually modelled into the hard parts, the first place I noticed this other than the shoulders were the shin armour pieces. Pretty much the entire outside of the part needs to be removed, unlike the shoulders however where the plastic to be removed on the shoulder is thin (Less than the wall thickness) the bits to be removed here were thick enough that the infill would be exposed around the entire edge of the part, effectively having the outside and inside skins held in place with just infill... that wasn't going to work.
So that was the shins, I also saw other issues with the shin, parts being the wrong shape, too thin, too fat, not detailed in some places. Let me take a look at the other parts then. Oh my... the knees, thighs, shoulders and most importantly the torso armour were all also wrong too. The torso being the biggest issue, there's actually a part of the back which was modelled as a hard part which is actually a soft part! Not to mention some other pretty major details that are just wrong.
THE INSANITY BEGINS
Okay well it's okay, maybe I can just modify the files a little. I come from a CAD background but I used 3DS Max maybe a decade ago... how hard can it be?
Well as it turns out... incredibly...
I've never used Blender before, so I was hitting the ground running. Pretty quickly it was found that 1) the 3d printed model files were derived from the ripped model from the archive 2) the 3d printed models were hard to modify given they had been subdivided and triangulated. I could have turned them to quads and decimated them but large details would probably have been destroyed.
So here's where the insanity comes in. I decided to just model the parts again from scratch. The benefit of this is two-fold. 1) I can make the armour accurate to my specification and 2) I can add some functionality that is sorely missing to the armour!
My first ever Blender part! Reference on the left, my part on the right!
Forgive the terrible modelling, if you saw some of the topology you'd blush... but I think it'll do it's job! Especially when getting printed through a 3d printer, some of the crimes will be hidden! The biggest thing here is that now the parts which are supposed to be sharp are sharp, details are added, soft parts are removed and the part is also ready for functionality... :unsure: you may see that there's some bit's missing off of my model, specifically the hinge mechanism is missing and the silver piece at the top of the knee
Ahhhh Fusion 360... that's more my speed... So actually I've not missed them, but the functional parts I chose to design in Fusion simply for tolerance sake. The hinge mechanism will meld perfectly with the armour plates and there's an internal built in stop so they can't over extend but will spring back into position. I'm pretty proud of my first foray but there was definitely places to improve. Especially after printing out some more functional test prints I severely underestimated how strong PETG can be! So I may redesign these parts to be slimmer.
The shin and knee armour was a nice way to dip my toes into hard body modelling in Blender. It was necessary but also it's in a location not so easily seen so I can get away with a bit more! Next part however was to address the biggest source of inaccuracy... the torso :oops:
I want to just say that I'm really really happy with how this came out! I took what I learned from the shin and knee and applied it to the torso, for me the biggest thing this does is adds functionality to all of the extraneous plates on the torso and my personal favourite part... I HAVE A FUNCTIONAL CAPE ATTACHMENT SYSTEM.
Reference on the left, my model in the middle, the original 3d printed part to compare on the right
This insanity started because I wanted to get the soft parts sorted and measured, that was put on hold when I found out the original 3d prints actually had the soft parts modelled into the print. If I went off of the parts I printed I would have made the soft parts a several cm larger in most every dimension! It might not be obvious but if you look at the difference between my model and the 3d print there's large areas that are removed (Around the front between the abs plate and front, all around the side plates and all the way up the sides of the main front plate)
The other thing that I noticed pretty quickly was the inside of the neck was completely empty (If you put the chest plate on I can almost fit my fist between my chest and the inside of the plate! Helldivers must have HUGE pecks!) I've decided to model that back in which also give a location for the tubes between the back and front to go to. I'm also thinking about adding more functionality to that area as well... maybe a water reservoir for a cool-suit? :unsure: There's a few small details I didn't model (Basically only small rivet heads) so that I can just sand the area flat nice and easily and not messing around tiny features that'd get worn away, I'll just glue these on later.
You can also see on the shoulder straps the cape attachment system! This part I am especially proud of, it's so damn satisfying! This all started because frankly I didn't like the detail on the shoulders anyway, and there was no real way to sand any of the parts to make them look half decent on the original, in the end the UV resin covered them and most of what little detail was there was gone, so I wanted a part I could print separately, sand all the nubbins off and glue it into place. Well eventually I figured why not make it work? It's just a simple latch, but this was my first time with compliant mechanisms on 3d prints, but I knew PETG was a good candidate anyway as it had a bit more flexibility.
So I mocked up a few different test pieces, this is my favourite part where I got to iterate quickly through different designs! My first test print (Top left) was not intended to clog the printer nozzle... and thus give me just a half finished part :unsure: but actually it was invaluable because the latch still worked! So it gave me a sectional view of the inside of the mechanism as I inserted the cape insert. (Aha! Just as intended!) I just reprinted the original test (Second from left) to see if that made any difference to operation. That was paired with the first 4.4mm cape insert.
Just to clarify, the way this works is eventually the cape will be sewn to the end of the inserts (I may try to mold the capes into the inserts somehow but that's for future me to worry about), the inserts are pushed into the latch and the latch snaps down, just the wiry looking part of the latch is actually glued so the chunky bit can flex to snap. I have a video but can't figure out how to embed just yet!
The 4.4mm insert was just a proof of concept, "does the latch flex and snap over the insert without breaking?"... the answer YES! Quite well actually. However it was very tight, I could have sanded it down but I figured it'd be easier to just reprint it thinner. My next iteration I wanted the insert to pop out when you unlatch it. I suppose I could have glued some springs into the receptacle but that would be fiddly and might mess up, there's no chance I could fish it back out if it went wrong, so I figure if I'm using one compliant mechanism why not use another? So the 4.2mm insert includes a 1mm bow across the front that can squish, when you unlatch it should pop out! This also worked quite well especially with the thinner insert meaning it wasn't getting jammed up, but I wanted a little more oomph when it popped out. So I increased the bow radius and made it thinner again. The 4mm thickness was perfect, but my next problem was the increased bow meant that the latch actually snapped down into the area inside the bow. Giving you a false positive click so it'd just fall out super easily. So to fix that I added more nodules to the bow so the latch is constantly supported throughout travel. This works perfectly! It's also quite durable! I've been messing with it on my desk for a week at this point and it's gone through hundreds of cycles.
Finally I've also tested some hinges for the separate chest plates. Forgive the print, it looks rough but the part is incredibly strong! As it should be since it has a 6mm dowel pin going straight through it! With the layer orientation perpendicular to the axis of the shaft I'm confident that this will hold up to quite a lot of abuse! It certainly feels strong but I'd need to glue it to a test piece and try to break it to make sure! Importantly though it looks spot on to the in-game model despite having a rod going through the centre of it. Once it's painted silver it'll look much better!
I've just finished the model for the back today so figured I'd start a build thread for once! :D The back is where I find the most egregious mistake on the original file to be. Again reference on the left, my model in the middle and 3d printed model on the right.
The issue here is there's an extra hard plate added to bottom of the 3d print that shouldn't be there! From the looks of it this part should be some sort of rubbery urethane attached to the vest itself (There's literally edge beading sewn over that part along the bottom and it carries on into the rest of the vest with no seams!) The way to look at the layers is to remember the perk that this armour has in game... "Extra-padding". if you look at the hard armour, check out the edges and then you'll see some padding and edge beading, the edge beading goes over that bottom 'plate' so it definitely isn't part of the hard armour! Also the shader gives it a matte finish like the other non-hard armour parts so there's that too!
Overall I'm really happy with how the 3d models have come out! I'm looking to start reprinting the parts soon so hopefully I'll update this thread in a short while with more pieces!
Hopefully this isn't too long, let me know if you have any questions!
Chris
Follow up from my last post, lots of printing has happened that I'm excited to show; all of the torso is printed, some of it assembled but I still need to post process all of the pieces. Apologies for the pictures... it would appear that my camera picks out every single imperfection on the prints so it's a little hard to see past the sanding marks.
Front Torso
First up is the front torso, the main chest piece has the inner neck detail which was lacking before, and the shoulder latching cutouts are much more accurate. Managed to get all the 3d printed hinges printed for the side and abdomen plates and they all hold up incredibly well, there's very little play and virtually no lateral play. Although they're not glued in place yet so the geometry between the plates doesn't look quite right in my picture with them all together below. All of the plates will be more angled away from the camera.
I printed out one of the side panels however it ended up being too thin and felt too flimsy so I increased the thickness to about 4mm, this appears to be the golden thickness for having a thin yet sturdy plate while still maintaining some flexibility. However this did allow me to test what the hinges would look like in situ with the original test hinge from last week. I really like how the two parts stack up, it feels much more like a manufactured part than a 3d print with the gap between them.
Here's the abdomen plate with hinge, the camera really didn't like the look of this hinge but it's actually very smooth in person! I think once they've got a layer of resin and primer it will all look a lot better on camera! But the hinge works flawlessly and operates nice and smoothly.
Back Torso
The back torso is also fully printed, the actual back on the original 3d printed files weren't actually that bad. They weren't perfect and there were a few missing details however they would have been functional if I had enough material to trim off the edges where the fabric was modelled underneath the plates along the edges, however doing so would have exposed the infill so that wasn't going to work unfortunately.
The biggest change however from the original files is the shoulder area, I included the proper slots cut out to accept the cape inserts that I had tested in my previous post. The inserts fit in perfectly so I'm happy with how they worked out in the print. There's also an area towards the back of the shoulders which actually should have a hole for passing 40mm webbing through, so I added the holes for that too. It really adds to the armour since it gives it a bit more texture.
Tac Pad
As well as the torso, I also redesigned the tac pad that goes on the left arm. The ripped model from the game does have it, however it's pretty much unusable in it's current state, it was easier to just redo it from scratch and use the in game model as a reference, the original 3d printed models were obviously derived from this model mainly because none of the faces were flat! They were all a bit wonky so redesigning it was a must if not for simply making it easier to print! I decided to do it in Fusion 360, it just seemed a lot easier to get all the details I wanted and this is less of a free-flowing shape to suited a proper CAD system better than Blender. This got printed out and I'm really happy with the small details that were missing from the other files. I don't know if the modellers working on the game planned this but the screen is exactly the same size as a 3.5" 16:9 display :unsure: that could make adding functionality to this nice and convenient!
Soft Parts
I hadn't forgotten about the soft parts for this armour! I haven't done any more patterning (I wanted a fully assembled updated torso at least before I started that) however I did start collecting all of the parts and materials required. Most of which have arrived now so I'll be starting to pattern some bits soon.
The main fabric for the exterior of the armour is 1000D cordura as mentioned in my last post, it comes in a wide variety of colours (So potentially if I fancy doing other armours from the game I can do them in the proper colour). I got it here: D10 - 1000 Denier Heavy Duty Texturised Nylon PU Coated
The interior of the armour will use padded spacer mesh fabric, this is the mesh looking stuff you see on hiking rucksacks and plate carriers. It's breathable so it should be more comfortable... plus it'll look better and more professional! I got it here: PM300 - Padded Mesh / Spacer Mesh
For the padding inside the armour I used a polyurethane foam, I was originally going to use an EVA foam instead but by the time I got all the bits required it'd be weirdly expensive for the thicknesses required and the amount required. While I was searching I actually found "Sound proofing closed cell foam" which as far as I can tell is PE foam with an adhesive backing. This is perfect because I can stick it to the inside of the cordura so there's no visible sagging or bunching up on the exterior of the parts!
To finish off the edges I picked up some 50mm PU edge banding, it's a "faux leather" look but actually it matches the references quite well, it's not too shiny and has a slightly rough appearance so I think it'll work well, it's also supple and slightly stretchy so it should have no problems going around corners like normal bias tape.
I picked up some 100mm wide velcro tape too, I may not actually need this but I thought it'd be useful to have!
One of the more annoying bits are these oval eyelets, they aren't expensive but they only come in packs of 100... which is annoying when you only need 2 of them! But alas... Also the forming tool costs £60+... NO THANKS! I'll just 3d print a form to hammer them out, if it wears out after 2 that's fine by me!
I still need to pick up buckles, I don't think the ones modelled on the armour actually exist in real life, if anyone recognises them though please let me know! The closest I can find are these which are probably a bit rubbish but should do in a pinch if I can't find anything else (this can always be done last anyway):
Finally I think I had a revelation about the jacket work under the armour. I've seen a lot of discussion about old greatcoats, or modified BDUs however I think that actually the jacket is just a simple soft shell jacket. I happen to have a soft shell jacket from when I was a bit larger so it was a size larger than me, and the bottom of the jacket hung around where it should be and the material also matches the references. I'll be trying this out before going down another route as that would be really easy! Just get a black soft shell jacket and add the yellow tape to the edges. Although it would be very hot as those jackets are always very warm!
Anyway that's my update this week, hopefully should have the torso sanded and ready for painting next week!
Cheers
It looks awesome so far! I am working on a Heros of the Federation armor set. Do you have the tac pad stl posted on a site anywhere or could i get the stl? I have been looking for one everywhere and have not been able to find it. I am doing to mod it to hold me phone and make a sound board so i can play sound clips from the game. Thanks in advance!
leotart Thanks! Sorry I hadn't been updating, summer rolled around and this sat project on the back burner. The Hero of the Federation suit looks awesome, gives me Judge Dredd vibes! About the tac pad, sure, I'll DM you with the STL, just don't go selling it or publishing it yourself :) Although just to let you know it's only 14cm x 8.5cm in size so you may have difficulty fitting a phone in inside it unless you have like an iPhone 5 or something! haha my Galaxy S23 is longer than the tac pad for reference. But anything is possible with a bit of fiddling!
Your reply also reminded me to update this thread! :D
Not a huge amount has happened since my last update however there have been a few exciting bits. The biggest thing is I have finally done multiple passes of sanding on the torso and glued it all together! This turned out to be a bit more difficult than I was expecting due to the hinged sections, simply because when I wet sanded them the pins started rusting and seizing the movement which I should have predicted to be honest! So I had to punch the pins back out and clean them off before installing them again. I'll also be oiling them after the primer has been applied. That being said I really like the hinged side plates, when test fitting they conform to my body really well and especially when bending over the hinged abs plate makes a huge difference! So I'm glad I went through with that!
Next up was the shin armour, I made a few minor adjustments to the shin armour since it was the first thing I modelled, there were definitely a few improvements I wanted to make. However I fixed those and printed both left and right. You can see the comparison between the newly modelled and original file below. My one looks much smaller however that's only because of how much extra the modelled fabric lining made up. The actual "armour plate" areas are the same size although my rendition has a bit more accurate geometry. I haven't started sanding these bits yet.
Finally the last part I attempted was to start sewing some of the soft parts to make the padding, specifically the side plate parts of the torso. I wanted to start off small and work my way up to the larger sections. This has been the hardest part to be honest although I definitely think I'm on the right track! The problem is the sewing machine I have access isn't beefy enough to get through all the layers the layer stack is like so:
PU edging fabric
Cordura
Foam
Cordura
Velcro (In some places)
PU edging fabric
I think I'm going to have to rethink how I make the pads, I'm thinking of 3d printing some edge beading in TPU that will keep the shape I want but then will have a hollow section so the sewing machine is not punching through the foam. That's still in the testing phase though.
So that's my update, Not hugely exciting but some progress has been made!
Cheers
PU edging fabric
Cordura
Foam
Cordura
PU edging fabric
Cheers
Hey AstroChris! Amazing work on the armor. Really love the level of detail you put in everything. I just finished my armor for a convention and after a lot of trial and error I discovered that: You need way more velcro than you might think (especially if you want everything to stay where it is meant to while moving, bending, jumping). All the soft parts are heat capturing parts, so if you intend to wear it in warm weather keep em breathable. The tac pad is an amazing place to hold your phone (I just stretched the middle in fusion and hollowed it out for the perfect fit).
Can't wait to see the final result!
YO HOLY CRAP THAT LOOKS ABSOLUTELY INSANE, I've been struggling to find suitable Helldivers 2 armour and yeah I also noticed the models that can be bought doesn't have the same fidelity as yours, I was hoping to find out if there's any way to get your stl files?
Right now I'm still a student so I have access to the school's 3d printers and sewing machines, I'm hoping on adding my own colour schemes and etches onto the models since I dabble a little with art and have experience with heavy duty tools like laithes, drill presses and etc. I'm studing mechatronics so I think I could also get some extra hardware in them too
I stumbled here from a Google about armor parts without the padding modeled in and I just had to create an account to say how impressive this project is. I wish I had the talent/know how to create models like that.
As a big Helldivers fan I must also commend you on the level of detail you're putting into the models. I would buy and print this over anything out there currently.
Please tell me there's a way to obtain the models? I was planning on just wearing a helmet around while taking the kids trick or treating, but if I could print this, I'd consider going all the way.
PU edging fabric
Cordura
Foam
Cordura
PU edging fabric
Cheers
This is crazy good. I recently bought the galactic armory files and noticed the same and started trying to think of ways to fix it lol. If you're cool with sharing I'd love to get my hands on your files. I just want to print accurate pieces!
PU edging fabric
Cordura
Foam
Cordura
PU edging fabric
Cheers
Hey is there any way I can get the models so I can print these out for my costume?
Same, but just for the wrist pad! My family are going as Helldivers to Comic con next year... 6 of us. We have Everything we need except the wrist pad and the intel pad that hangs on your waist. I have zero artistic ability to create these on my own - I actually ripped the 3d model files for an armor set I wanted that I couldn't find for sale; no joy :lol:.
