Ha, I wish mate!
My new tube arrived last week, so Iv'e cut it to the right size with the 60% cut. Of course the measures are slightly diiferent now compared to the 5 1/2" tube of which I'll [post soon with some piccys.
After alot of thought regarding the cockpit cone Iv'e decided to vac-form it over a turned buck (which is done) for the initial layer, then lay up the next layer manually while still on the buck. This will result in a strong cone with the desired thickness. Windows will then be cut out & underneath plating glued on.
Another batch of kits arrived/arriving soon including the M8 carrier which has always been elusive to me.
One thing that has become apparent with the Bandai Panther strips is that they 'taper' in considerably towards the bottom of the cockpit. This was throwing my kit placement out heaps, but after realising this was the case, ill do the same on mine, which will result in all donors fitting sweet.
Stu
Stu
