Darth Kahnt
Sr Member
Looking better all the time. Great progress shots.
Okay, after my break for Christmas and new years, I started up on this again.
After several failed attempts to created the 6 LED's from other materials, and upon remembering how cheap a bulk box of LED's was...I just used 6 of those instead. I had to cut a channel out of the granitex I used for the inside of the control box so that they would fit, then I cut out a sheet of styrene and drilled 6 holes in it for the LED's. I glued it on with liquid nails, filled all the gaps and sanded it to shape. I also filled some of the gaps around the saber. Next up on the agenda for this saber, is to shim up the shroud and center band with thin plastic and glue it on. After that comes paint, which, with it being the dead of winter here where I live, may not be possible anytime soon.![]()
But, alas, the picture:
[/b]
Okay, I can't paint the thing because it's still cold as heck outside.
But, in the mean time, the last little detail I need to finish up before I can glue this baby together is eluding me.
I don't know how to make the ring at the top of the shroud. I don't want to use solder because its too soft. I can't use a paperclip because it's not thick enough and it's too stiff to bend.
Does anybody have any know of something I can use? Some type of wire that will easily bend into a circle but not be overly soft? It needs to stand up to some abuse. Any suggestions would be hot.
[/b]
I'll post up a few pics later on today.
[/b]
